- Fokker XB-8
Fokker XB-8
12 years ago
Main AdminText from J.Baugher Thanks
The Fokker Aircraft Corporation of Teterboro, New Jersey (formerly known as the Atlantic Aircraft Corporation) was the American subsidiary of the famed Dutch-based Fokker corporation. Fokker was a pioneering designer of monoplane aircraft for both the civilian and the military market.
In 1929, the Fokker design department at Teterboro developed a proposal for an observation aircraft that could replace the Douglas O-25. The aircraft (designated Model 16 by the company) was a true cantilever monoplane with no struts or rigging wires. The plywood-covered high-mounted wing was similar to those fitted to contemporary Fokker commercial aircraft and was made of wooden box spars with plywood spars and ribs, covered with a plywood veneer. The fuselage was made of steel tubing and was covered with fabric. The aircraft was powered by a pair of Curtiss V-1570-9 Conqueror twelve-cylinder liquid-cooled engines mounted in the leading edge of the wing. The landing gear was retractable, the first such to be fitted to an Army Air Corps observation or bombardment aircraft. The main gear members retracted backwards into the rear engine nacelles, but the wheels remained only partially enclosed. Three crew members (1 pilot plus two gunners) could be carried in open cockpits. Armament was to consist of two flexible 0.30-inch machine guns, one operated by a gunner in a nose position and the other by a gunner in a dorsal position.
On June 19, 1929, the US Army Air Corps ordered two prototypes of the Model 16 from Fokker. The designation was XO-27. Serials were 29-327/328.
In response to the Fokker design, the Douglas Aircraft Corporation submitted a competing proposal for a twin-engined observation monoplane. On March 26, 1930, the Army ordered two example of the Douglas proposal, one being designated XO-35 and the other XO-36. The two planes were to be almost identical to each other, with the primary difference being that the XO-35 was powered by geared Conquerors and the XO-36 by direct-drive Conquerors.
The performance of the Douglas XO-35/36 and the Fokker XO-27 promised to greatly exceed that of the lumbering Keystone biplanes that were at that time the standard USAAC light bombers. Consequently, in 1929 the Army decided to have the second prototype of both designs completed as a light bomber rather than as an observation plane. The designation XB-8 was assigned to the Fokker design, XB-7 to the Douglas design.
The XO-27 (29-327) was first tested at Wright Field on October 20, 1930. The prototype was later fitted with an enclosure over the pilot's cockpit and was fitted with geared V-1570-29 engines, being redesignated XO-27A.
In 1930, Fokker-America was absorbed by the General Aviation Corporation, which was a subsidiary of General Motors, the large automobile manufacturing concern. On April 11, 1931, the company received a contract for six service test B-8s (two YB-8s and four Y1B-8s. Serials 31-587/592 were issued. On May 13, 1931, six service test Y1O-27s were ordered (31-598/603). They were broadly similar to the YO-27s. These were initially fitted with 600hp Curtiss GIV-1570C Conquerors, but these were replaced during December 1932 with GIV-1570F (V-1570-29) geared units.
The XB-8 (29-328) was delivered to Wright Field at Dayton, Ohio in February of 1931. After completing only a few flights, the XB-8 was damaged in an accident. It was repaired and test flights resumed. However, the XB-8 did not have as good a performance as the competing Douglas XB-7, and only one example of the XB-8 was built. The contract for two more prototypes and four service-test aircraft (two YB-8s and four Y1B-8s) was cancelled and was converted into a contract for six YO-27 aircraft. In any case, the advances in bomber design that took place in the early 1930s had become so rapid that both the XB-7 and XB-8 were quickly deemed obsolete and no production was ordered for either design.
The dozen production YO-27 and Y1O-27 observation aircraft were delivered to the USAAC between May 15, 1932 and January 6, 1933. The first YO-27 was issued to the 12th Observation Group based at Brooks Field, Texas. Five squadrons were ultimately equipped with these planes--two observation, two bombardment, and one pursuit squadron. These planes were operated primarily for radio practice flights, night navigation training, and long-distence cross-country practice flights. There were numerous accidents, most of which were caused by landing gear failures. However, the aircraft was relatively easy to fly, with no vicious flight characteristics. Surviving YO-27s were surveyed and scrapped during the mid 1930s and none survive today.
In 1933, the General Motors Corporation underwent a major reorganization and combined its General Aviation Corporation subsidiary into a large conglomerate along with other GM-owned aircraft companies such as Berliner-Joyce and the Curtiss-Caproni Corporation. This conglomerate was also known as the General Aviation Corporation. The complex of General Motors aircraft plants was later organized as the Eastern Aircraft Division and was to manufacture thousands of aircraft under license during the Second World War.
Serials:
29-327 Fokker XO-27
29-328 Fokker XB-8
31-587/592 Fokker YB-8 (delivered as YO-27)
31-598/603 Fokker Y1O-27
Specification of the Fokker/General Aviation XB-8:
Two 600 hp Curtiss V-1570-23 Conqueror twelve-cylinder liquid-cooled Vee engines. Maximum speed: 160 mph at sea level. Weights: 6861 pounds empty, 10,545 pounds gross. Dimensions: wingspan 64 feet, length 47 feet, height 11 feet 6 inches, wing area 619 square feet. Armed with two 0.30-inch machine guns, one in a flexible nose position and the other in a flexible dorsal position.
Regards Duggy.
