- Beech AT-10 WICHITA
Beech AT-10 WICHITA
11 years agoSat Dec 30 2023, 01:58pmDuggy
Main AdminIn 1940-1941 Beech Aircraft designed an advanced, multi-engine trainer that could be easily manufactured on a large scale. To conserve scarce metals needed for combat aircraft, Beech built the airframe out of plywood with only the engine cowlings and cockpit enclosure constructed of aluminum. The fuel tanks also were made of wood and covered with neoprene, a synthetic rubber. The extensive use of wood permitted Beech to subcontract the production of many components to furniture makers and other firms. The AT-10 had superior performance among twin engine trainers of its type, and over half of the U.S. Army Air Force's pilots received transitional training from single- to multi-engine aircraft in them.
Between 1941 and 1943, Beech built 1,771 AT-10s and Globe Aircraft Corp. (which became Temco after World War II) built 600 in Dallas, Texas.
ECHNICAL NOTES:
Engine: Two Lycoming R-680-9 radials of 295 hp each
Maximum speed: 190 mph
Range: 660 miles
Ceiling: 20,000 ft.
Span: 44 ft.
Length: 34 ft. 4 in.
Height: 10 ft. 4 in.
Weight: 6,465 lbs.
Below preserved at the National Museum of the United States Air Force
One AT-10 was experimentally fitted with a V-tail in 1945, hence it was redesignated XAT-10A.
