- Mission Builders HQ
- The Ops Room
- Cant get defence of Reich to work
Level 1Hi,
So I'm running 4.12 with up530
99% sure Ive got everything installed properly.
After I've chosen campaign it beeps when I click generate.
Am I missing a map or something?
Please help.
Cam -
Level 1= DGen 4.0.0.9 (01/05/05) =
seed: 177399625
DGen initialization. Side: de, Rank: 1
MaxBomberSkill=3
Distance=Any
Length=VeryLong
AI=Normal
Missions=Normal
AirIntensity=Medium
GroundIntensity=Medium
SlowFire=5.0
PromotionRate=1.000000
Career ID: DeB
Berlin:RVBerlin
Inherits RVBerlin
Wrong date: 19430817 120
10 years agoMon Aug 10 2015, 01:25pm
Main Admincamcam146, you?re using an ancient version of dgen.exe
EDIT:
just noticed that you?re talking about the RV campaign for Asuras dgen.exe mod, so you need to install Asuras mod, get it here:
http://www.axis-and-allies-paintworks.com/download.php?view.807
Level 1I thought I had but will try again.
Thanks
C. -
Level 1No luck.
Reinstalled Dgen and Defence of Reich campaign and still get the beep
Log:
seed: 1475410
DGen initialization. Side: de, Rank: 0
MaxBomberSkill=3
Distance=Any
Length=VeryLong
AI=Normal
Missions=Normal
AirIntensity=Medium
SlowFire=5.0
Career ID: DeB
Berlin:RVBerlin
Inherits RVBerlin
Wrong date: 19430817 120 -
Level 1K. the degen exe. file wasn't installing by the autoinstaller for some reason.
That was the problem.
Seems to work now.
C. -
Main AdminIf the installer doesn?t work for you, install it to desktop and copy the files with file explorer into the Il2 folder.
It?s also possible to unzip Asuras exe file with 7zip. -
Level 1Thats what I did. It worked.
Thanks for your attention to this matter.
I just bagged 3 B17Fs
C.
