  • Numerous outdated F-100Ds were modified as pilotless drones to give Air Force pilots and Army ground-to-air missile crews experience against realistic targets. These aircraft were redesignated QF-100.
    In August of 1979, a contract was awarded to Sperry Flight Systems for the conversion of 9 QF-100 drones. Two were YQF-100 development aircraft with added cockpit controls so that they could be flown by pilots for system evaluation. Three were built to standard USAF target configuration, three were built to Army requirements, and one was a two-seat version. The eight F-100Ds converted to QF-100 configuration had the serial numbers 55-3610, 55-3669, 56-2912, 56-2978, 56-2979, 56-3048, 56-3324, and 56-3414. The single F-100F that was converted had the serial number of 56-3984.
    Following these tests, a total of 209 QF-100 conversions were made by Tracor/Flight Systems Division from F-100s that had been preserved at the Davis-Monthan AFB in Arizona. These conversions were painted bright red-orange and had a few extra blade antennas for the transmission and reception of radio signals from the remote-controllers on the ground. The last QF-100 conversion by Sperry took place in April of 1985, but FSI was still carrying out QF-100 conversions at their Mojave, CA facilty for several more years thereafter.
    The takeoff of the QF-100 drone was directed by two ground-based controllers positioned at the end of the runway.
    20background
    2084
    20van
    Once airborne, the drone was handed off to a third controller sitting in a fixed-base ground station.
    20Evaluation
    20aircraft
    A dual redundant system was used to get the drone to the mission area and to select the maneuvers. The maneuvers were pre-programmed into on-board computers. If the drone survived the mission, it was flown back to the handover point, where the two controllers at the end of the runway brought it back in for a landing.
    The first unpiloted flight of a QF-100 took place on November 19, 1981 from Tyndall AFB in Florida.
    The first AMRAAM kill against a QF-100 took place on September 17, 1985. The lifetime of a typical drone was about ten flights before it was destroyed.
    2086
    20aircraft
    2088
    20flight
    2086
    2086
    2086
