  • Design and development
    After deliveries of the PBY Catalina, also a Consolidated aircraft, began in 1935, the United States Navy began planning for the next generation of patrol bombers. Orders for two prototypes, the XPB2Y-1 and the Sikorsky XPBS-1, were placed in 1936; the prototype Coronado first flew in December 1937.
    After trials with the XPB2Y-1 prototype revealed some stability issues, the design was finalized as the PB2Y-2, with a large cantilever wing, twin tail with very marked dihedral, and four Pratt & Whitney R-1830 radial engines. The two inner engines were fitted with four-bladed reversible pitch propellers; the outer engines had standard three-bladed feathering props. Like the PBY Catalina before it, the PB2Y's wingtip floats retracted to reduce drag and increase range, with the floats' buoyant hulls acting as the wingtips when retracted. The price of the PB2Y-2 was US$300,000, or approximately three times that of the PBY Catalina.
    20Diego
    20quadrant
    Development continued throughout the war. The PB2Y-3, featuring self-sealing fuel tanks and additional armor, entered service just after the attack on Pearl Harbor and formed most of the early-war Coronado fleet. The prototype XPB2Y-4 was powered by four Wright R-2600 radials and offered improved performance, but the increases were not enough to justify a full fleet update. However, most PB2Y-3 models were converted to the PB2Y-5 standard, with the R-1830 engines replaced with single-stage R-1830-92 models. As most existing PB2Y-3s were used as transports, flying low to avoid combat, removing the excess weight of unneeded superchargers allowed an increased payload without harming low-altitude performance.
    Coronados served in combat in the Pacific with the United States Navy, in both bombing and antisubmarine roles. PB2Y-5 Coronados carried out four bombing raids on Wake Island between 30 January and 9 February 1944.However, most served as transport and hospital aircraft. The British Royal Air Force Coastal Command had hoped to use the Coronado as a maritime patrol bomber, as it already used the PBY Catalina. However, the range of the Coronado (1,070 miles) compared poorly with the Catalina (2,520 mi), and the Short Sunderland (1,780 mi). Consequently, the Coronados supplied to the RAF under Lend-Lease were outfitted purely as transports, serving with RAF Transport Command. The 10 aircraft were used for transatlantic flights, staging through the RAF base at Darrell's Island, Bermuda, and Puerto Rico, though the aircraft were used to deliver vital cargo and equipment in a transportation network that stretched down both sides of the Atlantic, from Newfoundland, to Brazil, and to Nigeria, and other parts of Africa. After the war ended five of the RAF aircraft were scrapped, one was already lost in collision with a Martin PBM Mariner and the last four were scuttled off the coast of Bermuda in 1946.
    Coronados served as a major component in the Naval Air Transport Service (NATS) during World War II in the Pacific theater. Most had originally been acquired as combat patrol aircraft, but the limitations noted above quickly relegated them to transport service in the American naval air fleet also. By the end of World War II, the Coronado was outmoded as both a bomber and a transport, and virtually all of them were quickly scrapped by the summer of 1946, being melted down to aluminum ingots and sold as metal scrap, or used as targets for fighter gunnery practice.
    Only one known example remains, at the National Naval Aviation Museum at Naval Air Station
    Coronado I
    RAF Designation for PB2Y-3
    XPB2Y-1
    Prototype with four 1,050 hp (780 kW) Pratt & Whitney XR-1830-72 Twin Wasps, engines, one built.
    See above
    PB2Y-2
    Evaluation variant with four 1,020 hp (760 kW) Pratt & Whitney R-1830-78 Twin Wasp engines, modified hull and six 0.5 in (13 mm) guns, six built.
    20Coronado 1
    20Coronado
    2 1
    XPB2Y-3
    One PB2Y-2 converted as prototype for PB2Y-3.
    PB2Y-3
    Production variant with four 1,200 hp (890 kW) Pratt & Whitney R-1830-88 Twin Wasp engines and eight 0.5 in (13 mm) guns, 210 built.
    20Coronado
    20P
    PB2YCoronadothatlostawingtipfloat29October1943
    PB2Y-3B
    Lend-lease designation for Royal Air Force aircraft.
    PB2Y-3R
    PB2Y-3s converted by Rohr Aircraft Corp as freighters with faired-over turrets, side loading hatch, and seating for 44 passengers, 31 built.
    20Coronado
    20807
    20Beaching
    20Beaching
    20Beaching
    20Atoll
    201943
    20Ame
    20operat
    20Coronado
    XPB2Y-4
    One PB2Y-2 re-engined with four 1,600 hp (1,200 kW) Wright R-2600 Cyclone 14 engines.
    XPB2Y-5
    The XP2BY-3 converted as PB2Y-5 prototype.
    PB2Y-5
    PB2Y-3s converted with four 1,200 hp (890 kW) Pratt & Whitney R-1830-92 Twin Wasp engines, increased fuel capacity and provision for RATOG (rocket assisted take-off gear).
    20Coronado
    PB2Y-5R
    PB2Y-5s converted as unarmed transports, some fitted for medical evacuation role.
    Crew: ten
    Length: 79 ft 3 in (24.2 m)
    Wingspan: 115 ft 0 in (35 m)
    Height: 27 ft 6 in (8.4 m)
    Wing area: 1,780 ft? (165 m?)
    Empty weight: 40,850 lb (18,530 kg)
    Max. takeoff weight: 66,000 lb (30,000 kg)
    Powerplant: 4 ? Pratt & Whitney R-1830-92 radial engines, 1,200 hp (900 kW) each
    Maximum speed: 194 mph (168 knots, 310 km/h)
    Cruise speed: 170 mph (148 knots, 272 km/h)
    Range: 1,070 mi (930 NM, 1,720 km) at 131 mph (210 km/h)
    Service ceiling: 20,500 ft (6,250 m)
    6? .50 in (12.7 mm) M2 Browning machine guns in twin nose, dorsal, and tail powered turrets
    2? .50 in M2 Browning machine guns in manual waist mounts
    Bombs:
    2? Mark 13 torpedoes or
    Up to 12,000 lb (5,400 kg) of bombs, housed in the wings
    1jpg
    Colour
