  • Australia first showed an official interest in replacing its CAC Sabre with the Mirage III during 1960, and initially considered a variant powered by a licence-built variant of the Rolls-Royce Avon turbojet (used by the CAC Sabre). While an experimental Avon-powered Mirage III was built as a prototype and flown in trials, it did not result in use of the Avon by a production variant.
    The Australian government decided that the Royal Australian Air Force (RAAF) would receive a variant based on the Mirage IIIE and powered by the SNECMA Atar engine, built under license by Government Aircraft Factories (GAF) at Fishermans Bend, Melbourne. Known as the Mirage IIIO or GAF Mirage, the Australian variant differed from the Mirage IIIE mainly in its avionics. The other major Australian aircraft manufacturer at the time, the Commonwealth Aircraft Corporation (CAC), also based in Melbourne, was also involved in the project, producing the Atar engine under licence.
    Initially, Dassault provided a pair of pattern aircraft, the first of these flying during March 1963, which were transported to Australia and used to aid technicians at GAF in establishing their own assembly line for the type. GAF produced three variants: the Mirage IIIO(F), which was an interceptor, the Mirage IIIO(A), a surface attack aircraft and the twin seat Mirage IIIO(D), a fighter lead-in trainer. GAF completed 48 Mirage IIIO(F), 50 Mirage IIIO(A) and 16 Mirage IIIO(D) aircraft.
    Between 1967 and 1979, all the surviving Mirage IIIO(F) aircraft were converted to the Mirage IIIO(A) standard, which reconfigured them from the interceptor role to perform ground attack and aerial reconnaissance missions instead. During 1988, the Mirage III was finally withdrawn from RAAF service, after which 50 of the surviving fighters were exported to Pakistan in 1990. Several examples are preserved in museums around Australia; at least one of these is reportedly under restoration to an airworthy condition.
    20exercise
    2085
    20Thunder
    20SEA85
    2085
    20Consort
    20flying
    20exercise
    20exercise
    2084
    2084
    20exerci 1
    2084
    20exerci
    20he
    2084
    2084
    2084
    20SEA85
    20SEA85
    20SEA85
    20Squadron
    20aircraft
    2085
    20Darwin
    20SEA85
    20Consort
    20Consort
    2085
    20Consort
    20Consort
    20Consort
    20Consort
    20SEA85
    2085
    As usual right click.
