  • The Fieseler Fi 156 Storch ("stork") was a German liaison aircraft built by Fieseler before and during World War II. Production continued in other countries into the 1950s for the private market. It was notable for its excellent short field (STOL) performance and low stalling speed of 50 km/h (31 mph). French-built later variants often appear at air shows. Compared to most other liaison aircraft of the period, the Storch was quite large and heavy, with its wingspan exceeding 14 meters (nearly 47 feet) and its weight slightly over 1,300 kg (2,900 pounds) when fully loaded. It was significantly heavier, slower, and less agile than Allied liaison aircraft such as the American Piper L-4 or Stinson L-5, or the British Auster.
    Conception and production
    In 1935, the RLM (Reichsluftfahrtministerium, Reich Aviation Ministry) invited several aviation companies to submit design proposals that would compete for the production contract for a new Luftwaffe aircraft design suitable for liaison, army co-operation (today called forward air control), and medical evacuation. This resulted in the Messerschmitt Bf 163 and Siebel Si 201 competing against the Fieseler firm's entry. Conceived by chief designer Reinhold Mewes and technical director Erich Bachem, Fieseler's design had a far better short take off and landing ("STOL") performance. A fixed slat ran along the entire length of the leading edge of the long wings, while a hinged and slotted set of control surfaces ran along the entire length of trailing edge. This was inspired by earlier 1930s Junkers Doppelflügel, "double-wing" aircraft wing control surface design concepts. For the Fi 156, this setup along each wing panel's trailing edge was split nearly 50/50 between the inboard-located flaps and outboard-located ailerons, which, in turn, included trim tab devices over half of each aileron's trailing edge length.
    A design feature rare for land-based aircraft enabled the wings on the Storch to be folded back along the fuselage in a manner similar to the wings of the Royal Navy's Fairey Swordfish torpedo bomber. This allowed the aircraft to be carried on a trailer or even towed slowly behind a vehicle. The primary hinge for the folding wing was located in the wing root, where the rear wing spar met the cabin. The long legs of the main landing gear contained oil-and-spring shock absorbers that had a travel of 40 cm (15-3/4 inches), allowing the aircraft to land on comparatively rough and uneven surfaces; this was combined with a "pre-travel" distance of 20 cm, before the oleos began damping the landing gear shock. In flight, the main landing gear legs hung down, giving the aircraft the appearance of a long-legged, big-winged bird, hence its nickname, Storch. With its very low landing speed, the Storch often appeared to land vertically, or even backwards in strong winds from directly ahead.
    Starting with the C-2 variant, the Fi 156 was fitted with a raised, fully-glazed position for a flexible rear-firing MG 15 7.92mm machine gun for self-defense.
    German production
    About 2,900 Fi 156s, mostly C variants, were produced from 1937 to 1945. Main production was at the Fieseler Factory in Kassel, in 1942 production started in the Morane-Saulnier factory at Puteaux in France. Due to the demand for Fieseler as a subcontractor for building the Fw 190, Fi 156 production was shifted to Leichtbau Budweis in Budweis by the end of 1943. Factories in other countries under German control manufactured aircraft, including Fi 156s, for Germany.
    Soviet production
    In 1939, after the signing of the Molotov–Ribbentrop Pact, Germany provided several aircraft, including the Fi 156C, to the Soviet Union. Oleg Antonov was made responsible for putting the aircraft into production to meet Soviet requirements, and given a choice between designing an equivalent aircraft or merely copying the German design, the latter was selected. The aircraft was titled OKA-38 and two versions were envisaged: the SS three seat liaison aircraft, and the N-2 air ambulance capable of carrying two stretchers plus a medic. A prototype was constructed in Factory No. 365, established on the basis of Lithuanian Military Aviation Works, in Kaunas, recently occupied Lithuania. The first prototype however was built in Factory No. 23 in Leningrad and flew before the end of 1940. The production in Kaunas has just started as the factory was lost to the German advance in 1941. While Antonov's efforts had produced a heavier aircraft, which required as much as three times the field for landing and take off as the German Fi 156C (160 m vs 55 m), it also had much greater range and increased load capability. After the war Antonov went on to design the legendary An-2 STOL biplane, which also had excellent STOL performance.
    Production in Czechoslovakia
    In 1944 production was moved from the Leichtbau Budweis to the Mráz factory in Choceň which produced 138 examples of the Fi 156, locally designated as "K-65 Čáp". Production ended in 1949.
    Production in France
    During World War II, Morane-Saulnier was operated under German control and built a number of German types including the Fieseler Storch. Immediately after the liberation of France in 1944, the production of Fi 156 at the Morane-Saulnier factory was continued at the request of the Armée de l'Air, designated MS 500 Criquet for the batch of aircraft produced with the remaining stock of Argus air-cooled inverted V8 engines. Aircraft with further modifications and different engines (inline and radial) are known under different type numbers. The use of the aircraft in Indochina highlighted the weakness of wood for the construction of the airframe; it was then decided to build the wings of metal. Among the modifications, the defensive weapon aiming through the back window was dropped, although some aircraft were modified in the field to take a MAC 34T machine gun firing through one of the side windows. Some 141 aircraft were built before the end of World War II, and a total of 925 aircraft were built before the end of the production of all types of Criquet by Morane-Saulnier in 1965.
    Production in Romania
    Licence production was started in Romania in October 1943 at the ICAR factory in Bucharest. Only 10 were built by the time the ICAR factory was bombed in May 1944. Production resumed later in 1944, but only six were completed before repair work halted production. From June 1945 until 1946, a further 64 aircraft were built.
    The Storch was deployed in all European and North African theaters of World War II. In addition to its liaison function, a number were used to fly a battalion of Infantry Regiment Grossdeutschland behind enemy lines during the invasion of Belgium.
    Field Marshal Rommel used Storch aircraft for transport and battlefield surveillance during the North African desert campaign of World War II.
    In 1943, the Storch played a role in Operation Eiche, the rescue of deposed Italian dictator Benito Mussolini from a boulder-strewn mountain-top near the Gran Sasso. Even though the mountain was surrounded by Italian troops, German commando Otto Skorzeny and 90 paratroopers used gliders to land on the peak and quickly captured it. However, the problem of how to get back off remained. A Focke-Achgelis Fa 223 helicopter was sent, but it broke down en route. Instead, pilot Heinrich Gerlach flew in a Storch. It landed in 30 m (100 ft), and after Mussolini and Skorzeny boarded, it took off in 80 m (250 ft), even though the aircraft was overloaded. The Storch involved in rescuing Mussolini bore the radio code letters, or Stammkennzeichen, of "SJ + LL" in the motion picture coverage of the daring rescue.
    On 26 April 1945, a Storch was one of the last aircraft to land on the improvised airstrip in the Tiergarten near the Brandenburg Gate during the Battle of Berlin and the death throes of Nazi Germany. It was flown by the test pilot Hanna Reitsch, who flew Generalfeldmarschall Robert Ritter von Greim from Munich to Berlin to answer a summons from Hitler.
    A Storch was the last aircraft shot down by the Allies on the Western Front and another was downed by a direct Allied counterpart of the Storch, an L-4 Grasshopper, the military version of the well-known American Piper J-3 Cub civilian training and sport aircraft. The pilot and co-pilot of the L-4, lieutenants Duane Francis and Bill Martin, opened fire on the Storch with their .45 caliber pistols, forcing the German air crew to land and surrender.
    During the war a number of Störche were captured by the Allies. One became the personal aircraft of Field Marshal Montgomery. Others were used as the personal aircraft of Air Vice Marshal Arthur Coningham and Air Vice Marshal Harry Broadhurst, who acquired his Storch in North Africa, and flew it subsequently in Italy and North-West Europe.
    The British captured 145, of which 64 were given to the French as war compensation from Germany.
    Post-World War II
    The French Air Force (Armée de l'Air) and the French Army Light Aviation (Aviation Légère de l’Armée de Terre) used the Criquet from 1945 to 1958 throughout the Indochina War and the Algerian War. The Swiss Air Force and other mountainous European countries continued to use the Storch for rescues in terrain where STOL performance was necessary, as with the historically significant Gauli Glacier crash rescue in November 1946, as a pair of Flugwaffe-flown Storches were the sole means to get its twelve survivors to safety. After World War II, Storch aircraft were used in utility roles including agricultural spraying. Many Storches are still operational today and are commonly shown at air shows. In North America, both the Collings Foundation and the Fantasy of Flight museum have airworthy Fi 156 Storch aircraft in their collections.
    Fi 156 V1: Prototype equipped with an adjustable metal propeller, registration D-IKVN (produced in 1935–1936)
    Fi 156 V2: Prototype equipped with a wooden propeller. First prototype to fly (May 10, 1936). registration D-IDVS (produced in 1935–1936)
    Fi 156 V3: Prototype identical to the V2. Test machine for various radio equipment, registration D-IGLI (produced in 1936)
    Fi 156 V4: Prototype identical to the V3. Skis for landing gear and disposable auxiliary tank. (produced in 1936–1937)
    Fi 156 V5: Production prototype for A-series. (produced in 1937)
    Fi 156 A-0: Pre-production aircraft, identical to the V3. Ten aircraft were produced. (produced in 1937–1938)
    Fi 156 A-1: First production models for service, ordered into production by the Luftwaffe with an order for 16 aircraft, the first production aircraft entered service in mid-1937. Some sources cite that only six were effectively produced. (produced in 1938)
    Fi 156 B: Fitted with a new system which could retract the normally fixed leading edge slats and had a number of minor aerodynamic cleanups, boosting the speed to 208 km/h (130 mph). The Luftwaffe did not consider such a small difference to be important and the Fi-156 B was not produced.
    Fi 156 C-0: Pre-production. Essentially a "flexible" version of the A model. (produced in 1939)
    Fi 156 C-1: Three-seat liaison version. (produced in 1939–1940)
    Fi 156 C-2: Two-seat observation type, which had a raised, fully glazed rear dorsal gun position for mounting a MG 15 machine gun for defense. (produced in 1940)
    Fi 156 C-3: Replaced the C-1 and C-2 with a "universal cockpit" suited for any role. (produced in 1940–1941)
    Fi 156 C-3/Trop: Version adapted for tropical and desert conditions. Filtered intakes. (produced in 1940–1942)
    Fi 156 C-5: Addition of a belly hardpoint for a camera pod or jettisionable auxiliary tanks. Some were fitted with skis, rather than wheels, for operation on snow. (produced in 1941–1945)
    Fi 156 C-5/Trop: Version adapted for tropical and desert conditions. Filtered intakes. (produced in 1941–1945)
    Fi 156 C-7: Three-seat liaison version. "Flat" cockpit glazing similar to the C-1.
    Fi 156 D-0: Pre-production version of the air ambulance version of the C model with a larger cockpit and extra rear fuselage-location starboard-side door for stretcher accommodation. Powered by an Argus As 10P engine. (produced in 1941)
    Fi 156 D-1: Production version of the D-0. (produced in 1942–1945)
    Fi 156 E-0: Liaison version identical to the C-1; 10 pre-production aircraft were fitted with tracked landing gear and were produced in 1941–1942.
    Fi 156 F or P: Counter insurgency version. Identical to the C-3 with machine guns in side windows and bomb-racks and smoke layers. (produced in 1942)
    Fi 156 U: Anti-submarine version. Identical to the C-3 with depth charge. (produced in 1940)
    Fi 156 K-1: Export version of the C-1 (Bought by Sweden).
    Fi 256: A five-seat civil version; two were built by Morane-Saulnier.
    MS.500: Liaison version. French produced with 240 hp French built Argus engine, as the Fi 156 had used.
    MS.501: With a 233 hp Renault 6Q inverted, air-cooled "straight six" engine instead of the Argus inverted V8.
    MS.502: Liaison version. Identical to the MS-500, with the Argus engine replaced by a 230 hp Salmson 9ab radial engine.
    MS.504: with a 304 hp Jacobs R-755-A2 radial engine.
    MS.505: Observation version of the MS-500 with the Argus engine replaced by a 304 hp Jacobs R-755-A2 radial engine.
    MS.506: with a 235 hp Lycoming engine.
    Mráz K-65 Čáp: Production in Czechoslovakia after World War II.
    Antonov OKA-38 Aist ("stork" in Russian): An unlicensed Soviet copy of the Fi 156, powered by a copy of a Renault MV-6 inverted, air-cooled straight-six engine (similar to the Renault 6Q), was starting production as the factory was overrun by German forces in 1941.
    Below prototype
    IKVN
    Below German
    Fieseler Fi 156 Storch Cockpit
    156 Cleveland Ohio September 1938
    Fieseler Fi 156 Storch Winter
     4487 Finland
    5 Storch Finland
    Fieseler Storch S Landed In Denmark On May 5 1945
    Fieseler Fi 156 Storch Ambulance
    Fieseler Fi 156 Storch Luftwaffe Otto Moritz Walter Model
    5
    Afrika Corp
    Fridl
    Fieseler Fi 156 Storch Colour
    Below Finnish
    Fieseler Fi 156 Storch Finnish
    BelowSwedish
    Swedish
    Below Swiss
    Fieseler Fi 156 Storch Swiss
    Kloten
    5
    ARU On The Ground
     Gallen
    Below Allied
    Fieseler Fi 156C3Trop Stork Stkz NM ZS WNr 5620 Captured And Used By Air Vice Marshal A Coningham In Egypt
    45
    Fieseler Fi 156 Storch American
    Fieseler Fi 156 Storch Was Captured By The British In The Western Desert In 1943
    Below French MS 500
    500
    Below Indochina
    Fieseler Fi 156 Storch Indochina
    Specifications (Fi 156C-2)
    Length: 9.91 m (32 ft 6 in)
    Wingspan: 14.25 m (46 ft 9 in)
    Height: 3.05 m (10 ft 0 in)
    Wing area: 26 m2 (280 sq ft)
    Empty weight: 930 kg (2,050 lb)
    Gross weight: 1,324 kg (2,920 lb)
    Powerplant: 1 × Argus As 10 V-8 inverted air-cooled piston engine, 180 kW (240 hp)
    Propellers: 2-bladed
    Maximum speed: 175 km/h (109 mph, 95 kn) at sea level
    Cruise speed: 130 km/h (81 mph, 70 kn) (econ. cruise)
    Range: 390 km (240 mi, 210 nmi) at 150 km/h (93 mph; 81 kn) and 1,000 m (3,280 ft)
    Service ceiling: 4,600 m (15,090 ft)
    Rate of climb: 4.60 m/s (905 ft/min)
    Guns: 1 × MG 15 machine gun
