- Mission Builders HQ
- Made in Germany
- Campaigns and Missions
- Kuban campaign - for stock IL2
13 years agoFri Oct 05 2012, 08:50am
A dynamic campaign for Luftwaffe and VVS pilots with self installer.
The campaign contains the following subcampaigns from 1942 till 1944:
- Kuban 1942: Rush for asia
- Kuban 1943: Kuban 1943
- Prohorovka 1943: Zitadelle
- Kuban fall 1943: Retreat from Kuban
- Crimea 1944
Historical correct plane set and skins for all units (if possible in IL2). Luftwaffe missions are mostly flown in Rotte or Schwarm formation, like it was common at the eastern front.
The campaign was tested with IL2 1946 Pacific Fighters and DGEN.EXE V 4.0.8.6.
For the campaign i made extensive use of mission templates which are available for use from some guys and put it to the campaign mis-files. As a result, you will see much more populated maps, airfields and a very nice and populated town of Novorossik.
A big thx to the creators of the map templates:
- CrashBangWallop
- Beebop
- NHawk52
- lowfighter
- zbw_109
- JackPof
- Jadehawk
get the campaign files here:
http://www.axis-and-allies-paintworks.com/download.php?view.526
You will also need the concerning skin pack for the Kuban campaign:
http://www.axis-and-allies-paintworks.com/Skins/Boelcke/Kuban_skinpack_modded_1_0.zip
DISCLAIMER:
The campaign file pack pack is a non commercial product. Every commercial use is denied by the author.
Do not upload the campaign anywhere else or alter the campaign files.
Contact the author at http://www.axis-and-allies-paintworks.com/ for permission. -
Level 2Some action shots from the Campaign:
Great work, Detlev! -
Level 2I'm using the Kuban Campaign with the latest HSFX.
I would like to make use of the Bf 109 G4 in the 1943 Campaign.
Could you please give me instructions of which files should I have to edit to do that? -
elephant
that?s not an easy task, not all mod planes are working together with the stock dgen.exe on every map - it?s not a quick trial with the FMB, it?s a lot of editing files and a lot of trial and error, i?m sorry but atm i simply don?t have the time for it
Level 2OK, understood...
I thought it was something simpler that I could do it myself.
Never mind and thanks for the quick response! -
elephant
not realy, you need to understand the basic systematic of dgen programming
