- The Workshop
- Works in Progress
- Catch-22!
Catch-22!
Level 6 -
Level 6Also, anyone know how to shrink the noseart without making the resolution go down so much? -
Admin
I'm a little late answering but... the short answer is "no", it's unavoidable although you can possibly compensate by applying a little sharpening.
Maty12
Level 6What's sharpening, exactly? -
AdminIt's kind of hard to explain, but in this case I'd explain 'sharpening' as an effect used in programmes such as Photoshop to increase the crispness between different coloured pixels, for example the difference between the white and the blue on the port side nose art of 6C.
I'm a Photoshop user but I assume you're using Gimp? I've never used Gimp but I hear it's similar to PS... so in PS one selects the nose art layer then goes to the 'Filter' menu, scroll down to the 'Sharpen' menu then select one of the options there-in. I'd recommend applying only a little bit of sharpening and experimenting with it as it can have cons as well as pros. -
Level 6 -
12 years agoSat Jun 21 2014, 12:30am
Level 6 -
AdminSorry for such a late reply, how are you going with this? I see at SAS that mexchiwa will do some of that nose art for you which is good. -
Level 6The pack is taking a long time due to lack of reference for the camouflage planes. However, I'm doing Yossarian's plane today (6V "Dumbo"). I'm still not sure if 6P ("aBOMBinable snowman", later "Laden Maiden") was OD or desert tan. -
12 years agoTue Jul 01 2014, 10:27pm
Level 6I suppose I should probably update this thread, to catch up to the SAS one
As of today, we have:
6B "Passionate Paulette" (New version)
6C (New version)
6D "Free, Fast and Ready" (Awaiting mexchiwa's noseart)
6F "Superman"
6G "Booby Trap"
6H (Much of the camo created by me due to lack of reference)
6P as "The aBOMBinable Snowman" (Early stages of filming)
6P as "Laden Maiden" (Late stages of filming)
And finnaly 6V "Dumbo", Yossarian's plane and the first B-25C of the pack
Nothing is final yet, specially the camouflage planes, as their paintschemes are almost entirely fictional so far. Still not sure if 6P is OD or Desert Tan also.
