Beep
11 years agoLevel 1Brand new and excited to play this campaign. However whenever I hit generate all I get is a beep. I have Dgen 2.010 and the newer one 4.086?. I tried both, but no luck. I am running 4.12.2 and HSFX 7.02.2expert. Thank you for any assistance you can give me
AdminWhich campaign are you talking about?
When you hear a beep an error log file gets created in the games main folder. It is called Dgen_modERROR when you use Asura's DGen or DgenERROR when the old 4.0.8.6 version is used.
Post the error log file here and I will try to find the problem. -
11 years agoLevel 1The Solomon campaign. I am fascinated by it and your mod looks truly amazing. Im also looking at other DGen campaigns as well, but really want to start with this one. Here is the error log:
= DGen 4.0.8.6 (17/04/08) =
seed: 350040875
DGen initialization. Side: us, Rank: 0
MaxBomberSkill=3
Distance=Any
Length=VeryLong
AI=Normal
Missions=Normal
AirIntensity=Medium
GroundIntensity=Medium
SlowFire=5.0
PromotionRate=1.000000
Career ID: UsB
MrO_Tunis:Tunisia1
Inherits Tunisia1
Error - mapname was expected
Thanks for your help. -
AdminThe error log is from one of Boelcke's campaigns, not my Solomons campaigns. Moreover you are using the old 4.0.8.6 Dgen. You have to use the new one by Asura.
Try to start the Solomons campaigns with Asura's latest Dgen (2.0.1.2), it can be found here:
http://www.axis-and-allies-paintworks.com/download.php?view.807
If that doesn't fix the problem, show me the Dgen_modERROR log file that is created directly after you hear the beep. -
11 years agoLevel 1I didn't have a file loaded properly. Fixed it. Now it generates, but the briefs are in Russian. Don't care I can live with that. You have done an awesome job. Thanks for all you do.
AdminOpen the DGen_mod.ini file and change the language to English. If there is a ";" infront of the "Language=English" line you have to remove it.
11 years agoLevel 1Awesome thank you. I checked it before and it said English so I left tit alone; but it did have the semicolon in front of it. I will remove it.
