- Westfront campaign for HSFX 7 updated
11 years agoTue Mar 03 2015, 08:51am
get it here
http://www.axis-and-allies-paintworks.com/download.php?view.892
I?ve corrected a lot of bugs in addition with the new version od the data base files for Asuras dgen mod, available here, if you are using a former version of these files please update:
http://www.axis-and-allies-paintworks.com/download.php?view.891
now the pink P47 planes are gone which got the campaign crashing.
What?s new:
- Bug fixes
- Added the later parts of the war, the Battle of the Bulge, Operation Bodenplatte and Rhine crossings in spring 1945 to the campaign
- Added some more skins
- The RAF bomber campaign has now a part as night bomber in 1941 included
- The RAF figtherbomber campaign has also a part in 1941 as night prowler included, cause RAF started day light fighterbomber operation over France in 1942
- Added an additional subcampaign to the Luftwaffe part for 1941, defending the Battlecruiser fleet in the Port of Brest
- Hawk 75 as flyabale for the French fighter campaign insted of the P 36
- New missions and a lot of more stuff - explore it yourself, it?s to much to count it here.
Level 1I need help with this campaign who is showing me the same problem as MTO campaign
followed these steps
1 - installed and updated Il-2 1946 to HFX7.3
2 - installed Asuras Dgen mod( clicked, he asked me the Il-2 folder, checked "HSFX" and installed)
3 - Intalled the campaign with his Dgen and paintschemes(with USAAF, RAF and Luftwaffe skins already inside paintschemes) to the IL2 folder (overwriting folders).
4 - installed the "mod_files_for_hsfx_7_-_v1.4" four files in \DGEN\MOD folder
But still getting an annoying beep on generate campaign
so...
What i'm doing wrong??
the funny thing is i already had installed the previous versions of this campaign
http://www.axis-and-allies-paintworks.com/download.php?view.715
and worked perfectly. So may i still dont got something? -
11 years agoThu Jul 09 2015, 07:06am
Main AdminHi arsenius,
do you have a dgenmod_error.log file inside the IL2 folder? If so please post it here.
The sequence of the steps of installation you did is ok, i guess it could be a problem with the installation of Asuras dgen.exe mod. Please start some of the stock dgen campaigns and check if they are working or not. If they don?t work install Asuras mod one again. I recommend to install it into a dummy folder or to desktop and copy the files into the IL2 folder.
I need furthermore some more informations:
Which part of the campaign did you try, RAF, USAAF or Luftwaffe? Which part of the concerning campaign, 1939 or later or more than one?
Perhaps these threads will be helpfull for you?
http://www.axis-and-allies-paintworks.com/e107_plugins/forum/forum_viewtopic.php?11622
http://www.axis-and-allies-paintworks.com/e107_plugins/forum/forum_viewtopic.php?2705.80
11 years agoThu Jul 09 2015, 09:15am
Level 1
Which version of dgenmod are you using ?
arsenius
so...
As far as I am concerned I never use a dgen version different (and even more recent) from the one for which the campaign was designed : 2.0.2.0 in this case or for which the author (Boelcke in this case) explicitly tells it is ok
Level 1
jeanba
i'm using exactly the 2.0.2.0 -
Level 1
Boelcke
Hi arsenius,
Done, finally i made it work, thanks to your advices
what i've done? exactly as you asked me. extracted the .dat files from Dgen mod
from the HSFX folder in Asura's Dgenmod:
- Allclasses.dat
- Allplanedb.dat
- Allweapon.dat
To Dgen\Mod folder
and the:
- Dgen.exe
- Dgen_mod.ini
To Il-2 main folder.
When i activated the file "mod_files_for_hsfx_7_-_v1.4" files via JSGME he asked me to overwrite
- Activated the campaign the same way via JSGME
- Activated generic skins into Paintschemes\skin folder
VOIL?. no more annoying beep
People and Boelcke
thank you all
Main Adminyou?re welcome -
Main Adminbtw, the campaign will also work with asuras later versions of his dgen mod, atm it is 2.0.3.0 -
11 years agoFri Jul 10 2015, 03:03pm
Level 1Il' try it
11 years ago
Level 1
Thank you, if you say so, it is worth trying !
Boelcke
Shall I only use the executable (.exe file) ?
