- Westfront campaign for HSFX 7 updated
Main Adminthe exe file and everything what?s new for the DGEN\MOD folder - it?s my way for updates
10 years agoLevel 1
Boelcke
Indeed, the main feature about previous versions were the escort altitude
For instanc,e in my Spit XIV arnhem campaign, I had an escort mission where the escorted spit XVI flew at low altitude, I was prescribed to fly at something like 22000 feet and the intercepting ennemius were also at thsi altitude.
As I was not the leader, the Spit14 AI escorted the spit 16 at low altitude and the end result was a complete confusion, as the spit14 did not know whetehr to climb or not, (= sometimes they climbed, then they stopped climbing)the FW did not know whetehr to dive or not ... -
Main AdminDoes this happen with the new dgen.exe or the old version?
10 years agoMon Aug 24 2015, 10:24amLevel 1Hello
Sorry for my late answer :
I installed the new DGEN and things are much better
Made 2 missions with Spit 14, very hard because it is a high altitude fighter and it overheats quickly at low altitude.
Actually, I play "dead is dead" : If I lose, I create a new campaign, so more tension.
I scored only one kill, it was an assassination. Given the 4.12 AI, I spend most of my time checking my 6
I have one small problem during the debriefing : there is always the sentence "you were captured", I suppose this is a bug from DGEN
Anyway, thank you Boelcke for this nice campaign -
Main Adminthx for feddback Jeanba
10 years agoTue Aug 25 2015, 05:54pmLevel 1Ok, I quit the campaign because it is no more playable :
The situation is :
During the first one or two missions, the players's unit take very high casualties, then you only fly with 4 planes against 16 or more ennemies (not sure if there is a relation), given the AI, you are killed nearly immediatly after the beginning of the battle and you can only stop the campaign (which is done very quickly in "dead is dead mode" anyway).
I encountered this problem with the Normandie Niemen campaign too (Courland map).
Did you encounter this ?
You're not responsible, the 4.12 AI is responsible (or maybe I am a bad player).
Your work is sound, but DGEN fighter campaigns are not playable with any version above 4.10
The only possible problem is that I only had escort mission (which is not completly illogical)
Note : I can send you the generated missions if you want -
Main AdminI know about the problems with AI, i liked the 4.11 AI the most, 4.12 AI is hard because the difference between Ace, Veteran, Average and New is to small.
10 years agoTue Aug 25 2015, 08:12pmLevel 1Ace : you are shot down in 1 s, and veteran, it takes twice more time before being shot down
9 years agoLevel 1Hello
I modded a 4.10 install with all the options necessary for my campaign.
Now, things are much better and the campaign is highly enjoyable
Thank you for your work Boelcke
