- Mission Builders HQ
- Made in Germany
- Campaigns and Missions
- Korean airwar campaign
10 years agoTue Sep 29 2015, 10:13amMain Admin
The topic says it all - the campaign features
- a fighter campaign for USAAF and for the North Korean airforce,
- also a fighterbomber campaign for the USAAF
- and an US Navy part.
Made for HSFX 7.02 or better and Asuras dgen.exe mod.
Flyable planes:
F 80
F 84
F 86
F 51
F 4U
F 9F
MIG 15bis
it will be a little bit tricky because of the limitations from den.exe, there is no contry like north korea exisiting for DGEN.EXE and russian Planes are allies so you will have to fly the MIG 15 for Japan, but with the right marked skins it will work quite well.
AdminThat looks like an interesting project.
10 years agoMon Aug 17 2015, 06:35amMain AdminMany limitations with the map and with dgen.exe, but it?s possible - honestly i don?t have much knowledge about the korean war but i like the early jets and want to have campaign for them.
The first version of the campaign will have no moving frontlines, it covers the stalemate in summer/autumn 1951, but a lot of action in the air. Atm the beta is working quite good, i have to adjust the missions now.
If someone wants to support with testing i will be very gratefull - if not, i will work on
AdminYou could also do an early war sub-campaign when the North Korean Air Force was using Yaks and Il-10s against US F-80s and F-51s.
https://en.wikipedia.org/wiki/Air_Battle_of_South_Korea -
10 years agoMon Aug 17 2015, 01:35pmMain AdminThat?s the problem with the russian planes: It only works when these planes are defined as AXIS in the planes.dat file from Asuras mod. Doing this for the YAK?s and IL-100?s will crash all other existing dgen.exe eastern front campaigns.
With the Mig 15 it?s no problem, because there are no dgen campaigns existing which are using this plane. So it?s the only plane which does not cause problems.
Everything else is included in HSFX 7, with the exeption of the A 26 bomber which is vital for a Korean Airwar campaign. It?s the only thing you will have to add into HSFX 7 then. I?m talking about this plane:
http://www.sas1946.com/main/index.php/topic,41438.0.html
It works without problems in HSFX 7 together with Diffm mod. I will give links to these two mods and a short explanation how to install.
