  • Design and development
    Do K1
    The first Dornier Do K was the K1 which first flew on 7 May 1929. The K1 was a conventionally-braced high-wing monoplane, powered by a single nose-mounted 510 hp (380 kW) licence-built Bristol Jupiter VI radial engine, and had a conventional landing gear with a tailskid.The square-section fuselage had an enclosed cockpit for two with a cabin behind for freight or eight passengers. Test flights showed that performance was poor and the aircraft was redesigned.
    Do K2
    The Do K2 flew in December 1929 with similar wings and fuselage but had a changed landing gear and four 240 hp (179 kW) Gnome-Rhone Titan radial engines. The four engines were strut mounted on each side of the fuselage in tandem pairs, one in tractor configuration and the other as a pusher. Although the aircraft had an increase in available power, the performance was little improved on the K1.
    Do K3
    The K3 was a complete rethink of the design. The braced wing was replaced with a cantilever wing of larger span. The fuselage was changed to oval and stretched for two extra passengers and the tailskid was replaced with a tailwheel and the main units were enclosed in fairings. The four engines were in the same tandem arrangement as the K2, but located lower on the fuselage and changed to 305 hp (227 kW) Walter Castor radial engines. The performance was greatly improved but still provoked little interest and no others were built.
    Below K3
    31
    6
    5
    Cockpit
    20Messner
    20K3
    2 1
    7
    General characteristics K3
    Crew: two
    Capacity: ten
    Length: 16.65 m (54 ft 7? in)
    Wingspan: 25 m (82 ft 0? in)
    Height: 4.55 m (14 ft 11? in)
    Wing area: 89 m2 (958.02 ft2)
    Empty weight: 4265 kg (9403 lb)
    Gross weight: 6200 kg (13669 lb)
    Powerplant: 4 ? Walter Castor radial piston engine, 227 kW (305 hp) each
    Maximum speed: 230 km/h (143 mph)
    Range: 800 km (497 miles)
    Service ceiling: 6000 m (19685 ft)
