- Miles M.20
Miles M.20
5 years agoMon Sep 20 2021, 10:11amDuggyMain AdminThe Miles M.20 was a Second World War fighter developed by Miles Aircraft in 1940. It was designed as a simple and quick-to-build "emergency fighter" alternative to the Royal Air Force's Spitfires and Hurricanes should their production become disrupted by bombing expected in the anticipated German invasion of England. Due to dispersal of manufacturing, the Luftwaffe's bombing of the Spitfire and Hurricane factories did not seriously affect production, the M.20 proved unnecessary and the design was not pursued.
At the outbreak of the Second World War in September 1939, Miles Aircraft began work on a single-engined fighter to supplement the RAF's Spitfires and Hurricanes. A wooden mock-up of the design, the M20/1, was inspected by Sir Kingsley Wood, the Secretary of State for Air, but no orders followed. Following the outbreak of the Battle of Britain in July 1940, the Royal Air Force was faced with a potential shortage of fighters. To meet the Luftwaffe threat, the Air Ministry commissioned Miles to design a simple easy-to-build fighter to specification F.19/40. This became the Miles M.20/2. Nine weeks and two days later the first prototype flew.
To reduce production time the M.20 employed all-wood construction and used many parts from the earlier Miles Master trainer, lacked hydraulics, and had spatted fixed landing gear. The fixed undercarriage freed space and payload sufficient for twelve .303 Browning machine guns and 5000 rounds, and 154 Imperial gallons (700 litres) of fuel (double the range and ammunition capacity of the Hawker Hurricane and Supermarine Spitfire). The M.20 was fitted with a bubble canopy for improved 360-degree vision.
In line with a design philosophy emphasising simplicity, speed and re-using available components, the engine was a Rolls-Royce Merlin XX "power egg" identical to those used on Merlin-powered Avro Lancasters and Bristol Beaufighters. This conferred flight performance that fell between those of Britain's two frontline fighters.
Testing and evaluation
The first prototype, with the B-class serial U-9 first flew on 15 September 1940, and was tested at the A & AEE under the military serial number AX834 against Specification F.19/40. Armed with eight .303 Browning machine guns like the Hurricane, the M.20 prototype was faster than the Hurricane but slower than Spitfire types then in production, but carried more ammunition and had greater range than either. As the Luftwaffe had been defeated over Britain, the need for the M.20 had vanished and the design was abandoned without entering production. The first prototype was scrapped at Woodley.
A second prototype, U-0228 (later DR616) was built to Specification N.1/41 for a Fleet Air Arm shipboard fighter, equipped with an arrestor hook and catapult launch points. It first flew on 8 April 1941. This variant could be launched by catapult aircraft merchant ships which lacked flight decks so the aircraft were to be ditched after their mission, and to facilitate this the undercarriage could be jettisoned. However, obsolete Hurricanes were modified to fill this role, which rendered a shipboard variant of the M.20 unnecessary. Consequently, this prototype was also scrapped.
Specifications (M.20/4)
Crew: one pilot
Length: 30 ft 8 in (9.35 m)
Wingspan: 34 ft 7 in (10.54 m)
Height: 12 ft 6 in (3.81 m)
Wing area: 234 ft? (21.74 m?)
Empty weight: 5,908 lb (2,685 kg)
Max. takeoff weight: 8,000 lb (3,629 kg)
Powerplant: 1 ? Rolls-Royce Merlin XX V12 inline engine, 1,260 hp (940 kW)
Maximum speed: 333 mph (290 knots, 536 km/h)
Range: 920 mi (800 nmi, 1,481 km)
Service ceiling: 32,800 ft (10,000 m)
Climb to 20,000 ft (6,100 m): 9 min 36 s
Guns: 8 ? .303 inch Browning machine guns
