Saab 18
3 years agoSun Apr 12 2020, 10:39amMain AdminThe SAAB 18 was a twin-engine bomber and reconnaissance aircraft, designed and built by Svenska Aeroplan AB (SAAB) for use by the Swedish Air Force in response to a 1938 design competition. Due to delays, it did not enter service until 1944, but quickly became the standard Swedish bomber aircraft. Serving in the bomber, reconnaissance and ground-attack roles, it also assisted in the development of ejection seats and air-to-surface guided missiles until its replacement by the Saab Lansen in the late 1950s.
Intended as a replacement for the Junkers Ju 86 in service with the Swedish Air Force, the requirement that led to the Saab 18 called for a three-seat fast reconnaissance aircraft.
AB Svenska J?rnv?gsverkst?dernas Aeroplanavdelning (ASJA), SAAB, and AB G?taverken (GV) submitted designs for consideration by the Swedish Air Force. GV's GV8 appeared to be the best suited to the requirement; however, its cost and the departure of their chief designer resulted in SAAB ? the company having merged with ASJA in the meantime ? being awarded a contract for development of their design.
As a number of Americans were on the design staff of SAAB and ASJA, the Saab 18's design shared some similarities with American designs. The outbreak of World War II in 1939 led to a change of priorities by the Swedish Air Force, and production of the Saab 17 was accelerated, at the expense of work on the Saab 18, which, along with a change of requirements that added the role of medium bomber to the specification, resulted in the first flight of the aircraft being delayed until 19 June 1942.
Manned by a crew of three ? a pilot and navigator under a glazed, offset canopy, and a bombardier in the nose ? the Saab 18 prototype was a mid-wing monoplane with twin vertical stabilisers, and was powered by two Pratt & Whitney R-1830 Twin Wasp radial engines. Armament consisted of three 13.2-millimetre (0.52 in) machine guns, one fixed firing forwards and controlled by the pilot, the others being in flexible defensive mounts for use by the navigator and bombardier. Up to 1,000 kilograms (2,200 lb) of bombs could be carried in an internal bay, while up to eight 50-kilogram (110 lb) bombs could be carried on underwing hardpoints.
Flight testing showed that the aircraft was underpowered. However, as there was no immediate prospect for the acquisition of more powerful engines, the Saab 18 was ordered into production in both bomber (B 18A) and reconnaissance (S 18A) versions.
The B 18A entered service in June 1944, and quickly became Sweden's standard medium bomber aircraft. As license-built Daimler-Benz DB 605 liquid-cooled, inline engines had become available, they were incorporated into the improved Saab 18B, which first flew on 10 July 1944.
Ordered into production as the B 18B dive bomber, the 18B design was further developed into the T 18B, which was planned to be a torpedo bomber variant. Due to difficulties with the torpedoes, however, the T 18B was instead developed into a heavy ground-attack aircraft, mounting a 57-millimetre (2.2 in) automatkanon m/47 autocannon under the nose.
By the late 1940s, the third crewmember's position had been eliminated, reducing the crew of the aircraft to two; the provision of air-to-ground rockets and improved bombsights had removed the requirement for a bombardier. By this time the Saab 18 had established a reputation for suffering a serious rate of attrition, and this led to the decision to outfit all of the surviving aircraft with ejection seats for the pilot and navigator/gunner.
Production of the Saab 18 totaled 245 examples, with the last T 18B being delivered in 1948. Used in trials of early Swedish air-to-surface missiles, the Saab 18 remained one of Sweden's frontline ground attack and reconnaissance platforms until the late 1950s, when it was replaced by the jet-powered, swept wing Saab 32 Lansen, the B 18B and T 18B being replaced by the A 32A in 1958, with the last S 18As being replaced by S 32Cs in 1959.
Saab 18
One SFA STWC-3 engined B 18A prototype. The same prototype was later re-engined with SFA DB 605B engines as the prototype for the B 18B.
B 18A
The first production version, bomber aircraft powered by two SFA STWC-3 Twin Wasp radial piston engines and armed with three 13.2 mm akan m/39A autocannons, one fixed, two movable for defence. 62 built. The B 18A was quickly into its service life equipped with bomb forks to be able to dive bomb. All were converted into S 18A reconnaissance planes in 1946-47.
S 18A
Photo-reconnaissance conversion of B 18A, fitted with PS-18/A radar among other modifications.
B 18B
Dive bomber version, powered by two Daimler-Benz DB 605B piston engines. It was at the start armed with the same 3 autocannons as the B 18A but it was quickly downgraded to 2 due to the lower defensive one being borderline useless due its limited traverse and the limited view for the gunner. In 1946 the Swedish rocket-development program started and the B 18B was one of the planes used to test rockets of different types. In 1949-1950 all planes were redesignated as attack aircraft and got the ability to equip 12 light rockets or 8 light rockets and 2 heavy rockets. During the same period they also got ejection seats for the pilot and radio operator. Due to this the bombardier had to be removed and the radio operator lost his defensive gun. The defensive gun had become obsolete either way due to the jet era. Many of the planes that received ejection seats were also modified with a new rounded windshield. Very late into its service life it was used effectively as a reconnaissance plane where it mainly dropped flare bombs and got the same PS-18/A radar as the S 18A. 119 built.
T 18B
Attack version (originally projected as a torpedo-bomber), powered by the same engines as the B 18B. It was armed with the same fixed and upper defensive autocannon as the B 18B, but had 2 20 mm akan m/41 guns fixed in the nose. It had a bigger bomb bay originally designed for a torpedo[11], but the aircraft could equip a 1000 kg m/47 medium-capacity/general-purpose bomb or a 57 mm akan m/47 autocannon with 41 rounds instead, besides the original bomb loadouts of the B 18B. Early into its service it was also tested with the RB 302 anti-shipping missile which never entered service. In 1949 it received the same rocket and ejection seat upgrades as the B 18B, but could only carry 8 light rockets. In 1949 it was also tested with twin Bofors 40 mm L70's in place of its iconic 57 mm but the recoil shattered the nose glass, ending the tests. 52 built.
B 18A/B Dubbelkomando
Trainer version where the radio operator seat was turned around for an instructor. The armored shield between the seats blocked the instructor's view, but the conversion was considered worth it in the end as no new trainers had to be purchased and the plane could easily be reconverted for combat duty.
Specifications (B 18B)
Crew: 3: pilot/navigator, radiooperator/gunner, scout (at an early stage bombardier)
Length: 13.23 m (43 ft 5 in)
Wingspan: 17.4 m (57 ft 1 in)
Height: 4.35 m (14 ft 3 in)
Wing area: 43.75 m2 (470.9 sq ft)
Empty weight: 6,093 kg (13,433 lb)
Max takeoff weight: 8,793 kg (19,385 lb)
Fuel capacity: 1,700 litres (370 imp gal; 450 US gal)
Powerplant: 2 ? SFA DB-605B inverted-vee piston engines, 1,100 kW (1,475 hp) each (1700 with modifications)
Propellers: 3-bladed VDM-33
Maximum speed: 575?590 km/h (357?367 mph, 310?319 kn) depending on altitude
Cruise speed: 550 km/h (340 mph, 300 kn)
Stall speed: 80 km/h (50 mph, 43 kn)
Range: 2,600 km (1,600 mi, 1,400 nmi)
Service ceiling: 9,800 m (32,200 ft)
1x 13.2 mm fixed akan m/39A forwards-firing gun in wing root with 300 rpg
1x 13.2 mm movable akan m/39 defensive gun with 300 rpg
B 18B's delivered early had a second movable 13.2 mm akan m/39 defensive gun with 300 rpg for the scout (a leftover from the B 18A). This was quickly removed in the field due to the impracticality of it post-war and later production examples where delivered without it.
Loadouts:
Formally: 1,400 kilograms (3,100 lb) of bombs or 1,500 kilograms (3,300 lb) of bombs and rockets.Its biggest loadout was 2x 600 kg bombs and 12x rockets simultaneously.
Rockets:
Outer wings: ?299 kg max
8x 8 cm pansarraket m/46 AP-rocket (RP-3 rocket with Shot, 25 lb., "AP" Mk II head)
8x 15 cm spr?ngraket m/46 HE-rocket (RP-3 rocket with Shell, H.E. 60 lb., "SAP" No. 2 Mk Ihead)
8x 14,5 cm pansarspr?ngraket m/49A & B HEAT-rocket (Bofors 10.3 cm rocket with 14,5 cm HEAT head)
8x 15 cm spr?ngraket m/51A & B HE-rocket (Bofors 10.3 cm rocket with 15 cm HE head)
Belly: ?240 kg
4x 8 cm pansarraket m/46 AP-rocket (RP-3 rocket with Shot, 25 lb., "AP" Mk II head)
4x 15 cm spr?ngraket m/46 HE-rocket (RP-3 rocket with Shell, H.E. 60 lb., "SAP" No. 2 Mk Ihead)
4x 14,5 cm pansarspr?ngraket m/49A & B HEAT-rocket (Bofors 10.3 cm rocket with 14,5 cm HEAT head)
4x 15 cm spr?ngraket m/51A & B HE-rocket (Bofors 10.3 cm rocket with 15 cm HE head)
2x 18 cm halvpansarraket m/49A & B APHE-rocket (Bofors 18 cm rocket with 18 cm APHE head. At the start used primarily against ships but in the end against basically everything else.)
Bombs:
Bomb bay: ?1228 kg max
10x 50 kg minbomb m/37 medium-capacity/general-purpose bombs
10x 50 kg spr?ngbomb m/42 fragmentation bombs
10x 50 kg Lysbomb m/32 flare bombs
10x 50 kg Bombkapsel m/43 cluster bombs (holds 2x 12 kg spr?ngbomb m/39G fragmentation bombs & 1x 12 kg spr?ngbomb m/37 fragmentation bomb or 3x 6 kg brandbomb m/39 incendiary bombs)
10x 50 kg ?vningsbomb m/40 practise bombs
10x 8 kg ?vningsbomb m/40 practise bombs (addon mountings needed)
3x 250 kg minbomb m/37 medium-capacity/general-purpose bomb (central fuze with bent fins)
3x 250 kg minbomb m/40 medium-capacity/general-purpose bomb (central fuze with straight fins)
3x 250 kg minbomb m/50 medium-capacity/general-purpose bomb (nose & central fuze with straight fins)
2x 500 kg minbomb m/41 medium-capacity/general-purpose bomb (2 central fuzes with straight fins)
2x 600 kg minbomb m/50 medium-capacity/general-purpose bomb (nose fuze & 2 central fuzes with straight fins)
Inner wings: ?472 kg max
8x 50 kg minbomb m/37 medium-capacity/general-purpose bombs
8x 50 kg spr?ngbomb m/42 fragmentation bombs
8x 50 kg Brandbomb m/42 incendiary bombs
8x 50 kg Lysbomb m/32 flare bombs
8x 50 kg Bombkapsel m/43 cluster bombs (holds 2x 12 kg spr?ngbomb m/39G fragmentation bombs & 1x 12 kg spr?ngbomb m/37 fragmentation bomb or 3x 6 kg brandbomb m/39 incendiary bombs)
8x 50 kg ?vningsbomb m/40 practise bombs
8x 8 kg ?vningsbomb m/40 practise bombs (addon mountings needed)
