  • The USAAF had found by painful experience in World War II that fighter escort was absolutely vital for the survival of bombers in enemy airspace. Unfortunately, the first jet aircraft were notorious fuel hogs and lacked the range and endurance of their piston-engined counterparts, and would be unable to escort long-range bombers such as the B-29, B-50, and B-36 all the way to their targets. In an attempt to solve this problem, the USAF considered all sorts of proposals for markedly increasing the range of jet fighter escorts, some of which bordered on the bizarre. One proposal for the solution to the escort fighter range problem was for the bombers to tow their escorting fighters into the combat zone and release them when their protection was needed. Several experiments were made with B-29s or B-36s towing P-80 or P-84 jet fighters, none of them being very successful and some being downright dangerous. Other proposals revived the parasite fighter concept of the 1930s, this time with jet fighters being launched from platforms suspended from the bellies of large bombers. The best known example of this idea was the McDonnell XF-85 Goblin. Other ideas included the use of mixed power concepts such as that which produced the Convair XP-81. Others involved the construction of large, bulky fighters that were virtually flying fuel tanks, e.g., the Bell XP-83.
    Initial attempts to produce jet-powered fighters with the endurance of piston-engined aircraft (e. g. the Bell XP-83 and the Convair XP-81) were disappointing, and in early 1946, the USAAF informally requested proposals for a "penetration fighter" with a combat radius of at least 900 miles and a performance capable of meeting all opposing fighters on more than equal terms. In addition, the USAAF wanted to keep the gross weight of the aircraft below 15,000 pounds.
    Spurred on by the USAAF request, the McDonnell Aircraft Corporation of St. Louis, Missouri initiated work on the Model 36 on April 1, 1946. The Model 36 project called for a large twin-jet aircraft powered by a pair of 3000 lb. st. Westinghouse J34 engines. Originally, McDonnell had considered installing the engines in the wing roots, but this proved infeasible and the engines were moved to a side-by-side location in the lower central fuselage where they could be more easily reached for maintenance. The engines were fed by straight-through air intakes mounted in the wing roots. The jet exhausts were underneath the rear fuselage. This configuration, it was hoped, would leave enough space in the fuselage for the fuel needed for the long-range penetration mission. A 35-degree sweptback wing was fitted, and a V-tail was to be used. The V-tail arrangement was selected because of the desire to reduce compressibility effects, which was thought would be helped by cutting the number of tail intersections from three to two. A set of perforated dive brakes was mounted on the rear fuselage, hinged at the rear. The pilot's cockpit was situated well forward of the wing. The armament was to be six 20-mm cannon.
    The USAAF was sufficiently interested in the proposal that a Letter of Intent was awarded to McDonnell on May 7, 1946. On June 20, 1946, the USAAF awarded McDonnell a contract for two XP-88 prototypes. Serials were 46-525 and 46-526. A mockup was ready by the summer of 1946. Following inspection of the mockup in August, some changes were made. The wing root intakes were given 40 degrees of sweep and a boundary layer ramp was added on the intakes to improve pressure recovery. Early wind tunnel tests had indicated that the V-tail arrangement would result in adverse rolling moments due to rudder action and would produce insufficient longitudinal stability near the stall. Consequently, the V-tail was replaced by conventional swept surfaces, with the tailplane mounted partway up the fin to keep it in undisturbed airflow.
    The USAAF was satisfied with the changes, and confirmed the order for two prototypes on February 14, 1947.
    On June 11, 1948, the designation XP-88 was changed to XF-88 when the P designation was replaced by F. The name *Voodoo* was assigned, consistent wiht McDonnell's tradition of choosing the names of spirit-like apparitions for its aircraft.
    The first prototype (46-525) was rolled out on August 11, 1948. It was taken out to Muroc Dry Lake for testing. It made its maiden flight on October 20, 1948, piloted by McDonnell chief test pilot Robert M. Edholm. The powerplants were a pair of 3000 lb.st. Westinghouse XJ34-WE-13 axial-flow turbojets mounted side-by-side in the lower center fuselage. No armament was fitted.
    Some minor problems were encountered during the test flight program. Some loss of thrust was encountered during takeoff due to choking in the S-shaped air ducts. This was solved by fitting spring-loaded blow-in doors in the wheel well section of the ducts. The rolling rate was found to be insufficient. It was improved to a certain extent by increasing the aileron chord by 26 percent, but the full cure for this problem required an increase in the torsional rigidity of the wing. When the dive brakes were fully open, there was excessive buffeting. This problem was eliminated by perforating the brakes and restricting their opening angle to 45 degrees. In order to correct problems with inadequately damped directional oscillations and objectionable roll coupling, artificial means of stablization had to be devised, and a yaw damper system was adopted using a yaw rate gyro which controlled the rudder.
    With these changes, handling characteristics were generally satisfactory. However, performance was rather disappointing, due primarily to the demanding range requirements and to the weight increases which had taken place since the initial design phase. Maximum speed at sea level was only 641 mph, slower than that of the F-86 Sabre which was already in production. It took approximately six minutes for the XF-88 to reach an altitude of 30,000 feet. Initial estimates of a combat weight of only 16,500 pounds had proven to be overly optimistic, and the installation of additional equipment as requested by the USAF and the various modifications required as a result of flight testing were estimated to push the combat weight to over 20,000 pounds, making matters even worse. In order to satisfy the range requirements, the 734 US gallon internal fuel capacity was to be supplemented by 350-gallon wingtip tanks. However, wind tunnel testing indicated that serious stalling problems would be encountered when these tip tanks were mounted.
    It would appear that the XF-88 needed more power. McDonnell proposed to fit afterburners to the J34 engines that powered the second prototype, and the production F-88s were to be powered by 6000 lb.st. Westinghouse J46 afterburning turbojets. The USAF did not choose to fund the J46 installation, but they did approve the adaptation of the second prototype to the afterburning J34 engines. However, this adaptation proved more difficult than expected. Westinghouse found it difficult to achieve the additional thrust that was required with an afterburner only 52 inches long (the maximum which could be allowed due to ground clearance considerations). McDonnell was forced to develop the afterburner on its own. The length of the McDonnell-devised afterburner turned out to be only 30 inches and weighed only 218 pounds. It boosted the thrust of each Westinghouse XJ34-WE-15 engine from 3600 to 4825 pounds.
    The second prototype (46-526) was redesignated XF-88A, and was fitted with the afterburning XJ34-WE-15 engines. It was also fitted with bladder fuel cells in the wings to increase internal fuel capacity to 834 gallons. The XF-88A made its first flight on April 26, 1949. The performance improvement was apparent --- maximum speed at sea level was almost 700 mph, time to climb to 30,000 feet was cut to 4 minutes, and takeoff run was reduced by 20 percent.
    The XF-88A was faced with some stiff competition for the USAF penetration fighter order. The Lockheed XF-90 and the North American XF-93A had also been entered as contenders for the USAF penetration fighter order. The XF-90 was a twin-jet design which first flew in June of 1949. The XF-93A was a beefed-up derivative of the F-86 Sabre, initially ordered under the designation of F-86C. In the penetration fighter competition, the USAF initially favored the North American design because of its commonality with other Sabre variants, and in June of 1948 they supplemented the contract for the two F-86Cs with a contract for 118 production aircraft. In December of 1948, McDonnell was instructed to stop design and development work on the F-88, but was permitted to continue flight testing on the two prototypes.
    It would seem that the curtain had been brought down on the XF-88. However, the F-93A production contract contract was suddenly cancelled in February of 1949. Several reasons were given. Perhaps the most important reason was a severe reduction in the military budget for that year. With limited funds available, it was decided to give priority to interceptors and to strategic bombers. In addition, a Senior Officers' Board felt that no production order for any penetrator fighters should be awarded until a competitive flyoff between the three contenders could be carried out.
    The flyoff between the Lockheed XF-90, the McDonnell XF-88, and the North American YF-93A took place between June 30 and July 8 of 1950. On August 15, 1950, the Evaluation Board declared the McDonnell XF-88A to be the winner of the contest. However, McDonnell's victory was rather hollow since no penetration fighters were every actually manufactured or placed in service because wartime pressures mandated that priority be given to the procurement of existing types for use in Korea. In addition, the development of long-range, high-speed jet bombers such as the B-47 and the B-52 eliminated any real need for penetration fighters.
    At the request of the Air materiel Command (AMC), in October 1949 after completing its Phase I tests at Edward AFB, the first XF-88 (46-525) was returned to McDonnell for modification as the XF-88B, a propeller research vehicle. Provisions were to be made for testing 27 combinations of propellers driven by an Allison T38 turbine. The XF-88 was to be fitted with a 2750 shp Allison XT38-A-5 turboprop offset to port in the nose, and the nosewheel was to be moved to starboard. The non-afterburning XJ34-WE-13s were to be replaced by afterburning XJ34-WE-15s, and a fuel cell was to be installed in the wing as was done for the XF-88A. The fuselage fuel capacity was to be reduced to 543 gallons to provide space for flight test equipment. 240 pounds of ballast was to be placed in the rear fuselage to balance out the weight of the turboprop in the nose.
    Modifications began with the installation of the afterburning turbojets. However, before the turboprop engine could be installed, 46-525 had to be returned to the USAF to replace the XF-88A (46-526) which had been damaged on June 16, 1950. The turboprop installation was not completed until early 1952. It was first tested in flight on April 24, 1953. The XF-88B spent most of its time at the Langley Memorial Aeronautical Laboratory. It was joined by the damaged XF-88A in 1955, which served as a source of spare parts for the XF-88B. Testing continued until 1956. It had the distinction of being the final propeller-driven fighter in the USAF designation series.
    Although the F-88 never attained production status, it was the inspiration for the later supersonic F-101 Voodoo, which performed successfully in any number of roles, including penetration, escort, tactical strike, nuclear strike, photographic reconnaissance, interceptor, and conversion training.
    Following the completion of its testing, the XF-88A sat in a junkyard at Langley AFB in Virginia for several years. Both the XF-88A and the XF-88B were eventually scrapped.
    Below (46-525)
    McDonnell XF 88 Voodoo 42
    McDonnell XF 88 Voodoo 27
    McDonnell XF 88 Voodoo 11
    McDonnell XF 88 Voodoo 9
    McDonnell XF 88 Voodoo 8
    XF 88 Team After Flight 100
    McDonnell XF 88 Voodoo 65
    McDonnell XF 88 Voodoo 63
    McDonnell XF 88 Voodoo 62
    McDonnell XF 88 Voodoo 61
    McDonnell XF 88 Voodoo 59
    McDonnell XF 88 Voodoo 56
    McDonnell XF 88 Voodoo 46
    McDonnell XF 88 Voodoo 45
    McDonnell XF 88 Voodoo 44
    McDonnell XF 88 Voodoo 43
    McDonnell XF 88 Voodoo 40
    McDonnell XF 88 Voodoo 39
    McDonnell XF 88 Voodoo 36
    McDonnell XF 88 Voodoo 33
    McDonnell XF 88 Voodoo 29
    McDonnell XF 88 Voodoo 26
    McDonnell XF 88 Voodoo 25
    McDonnell XF 88 Voodoo 22
    McDonnell XF 88 Voodoo 18
    McDonnell XF 88 Voodoo 14
    McDonnell XF 88 Voodoo 13
    McDonnell XF 88 Voodoo 10
    McDonnell XF 88 Voodoo 7
    McDonnell XF 88 SN 46 525
    McDonnell XF 88 SN 46 525 In Flight
    Specification of the XF-88
    Engines: Two 3000 lb.st. Westinghouse XJ34-WE-13 axial-flow turbojets. Dimensions: wingspan 39 feet 8 inches, length 54 feet 1 1/2 inches, height 17 feet 3 inches, wing area 350 square feet. Weights: 12,140 pounds empty, 18,500 pounds loaded, 23,100 pounds maximum. Maximum speed: 641 mph at sea level. Climb to 35,000 feet in 14.5 minutes, service ceiling 36,000 feet, range 1737 miles. The planned armament of 6 20-mm cannon was not installed.
    Below (46-526)
    McDonnell XF 88 Voodoo 64
    McDonnell XF 88 Voodoo 60
    McDonnell XF 88 Voodoo 58
    McDonnell XF 88 Voodoo 41
    McDonnell XF 88 Voodoo 37
    McDonnell XF 88 Voodoo 28
    McDonnell XF 88 Voodoo 24
    McDonnell XF 88 Voodoo 23
    McDonnell XF 88 Voodoo 21
    McDonnell XF 88 Voodoo 20
    McDonnell XF 88 Voodoo 19
    McDonnell XF 88 Voodoo 17
    McDonnell XF 88 Voodoo 16
    McDonnell XF 88 SN 46 526 Second Aircraft Built During A Rocket Armament Test Fire
    McDonnell XF 88 Voodoo 57
    McDonnell XF 88 Voodoo 48
    McDonnell XF 88 Voodoo 47
    Specification of the XF-88A
    Two Westinghouse J34-WE-15 turbojets, 3600 lb.st. dry, 4825 lb.st with afterburning. Dimensions: wingspan 39 feet 8 inches, length 54 feet 1 1/2 inches, height 17 feet 3 inches, wing area 350 square feet. Weights: 12,140 pounds empty, 18,500 pounds loaded, 23,100 pounds maximum. Maximum speed: 641 mph at sea level. 706 mph at 20,000 feet. Initial climb rate 8000 feet per minute. climb to 35,000 feet in 14.5 minutes, service ceiling 39,400 feet, range 1737 miles. Armament consisted of six 20-mm cannon in the nose.
    Below XF-88B
    XF 88B Possibly On The Occasion Of Its First NACA Research Flight On 20 November 1953
    McDonnell XF 88 Voodoo 55
    McDonnell XF 88 Voodoo 54
    McDonnell XF 88 Voodoo 50
    McDonnell XF 88 Voodoo 34
    McDonnell XF 88 Voodoo 12
    McDonnell XF 88 Voodoo 53
    McDonnell XF 88 Voodoo 52
    McDonnell XF 88 Voodoo 51
    McDonnell XF 88 Voodoo 49
    McDonnell XF 88 Voodoo 38
    McDonnell XF 88 Voodoo 35
    McDonnell XF 88 Voodoo 32
    McDonnell XF 88 Voodoo 31
    McDonnell XF 88 Voodoo 15
    By late 1957, it was clear that turbojet and newer turbofan engines would represent the wave of the future in both the military and civilian spheres, and the NACA supersonic propeller research program was concluded with its final research flight on 17 January 1958. Over the course of its research career with NACA, the XF-88B accrued 28 hours of flight time with 43 research flights and three familiarization flights over a period nearly 50 months at Langley. Jack Reeder had conducted 30 research flights, while Bill Alford had 13 XF-88B flights in his logbook. NACA pilot Robert Champine had two familiarization flights for a total of 0.6 hours in the aircraft, while J. B. Whitten had one. While Jack Reeder continued in a long career with NASA, Bill Alford was killed the following year in England during a pitch-up event while landing a prototype Blackburn NA.39 Buccaneer. With the end of the supersonic propeller evaluation, the XF-88B was turned over the base salvage at Langley Field for disposition on 16 September 1958. The XF-88B was then transferred to Eglin AFB, Florida for ordnance testing. The XF-88B was tested to destruction at the proving grounds and removed from the USAF inventory in February 1959. Thus was the end to the distinguished career of the first Voodoo.
