- Grumman F4F-7
Grumman F4F-7
10 months ago
Main AdminThe F4F-7 was a proposed long range reconnaissance version of the Wildcat. Discussions had begun before Pearl Harbor but work did not begin in earnest until 1941.
The F4F-7 was a long-range photographic reconnaissance version with a total fuel capacity of to 695 gallons, with 555 gallons in non-folding wings filled with fuel tanks. This gave it the highest loaded weight of all Wildcats at 10,328 lbs. Missions as long as 25 hours and a maximum range of 3,700 miles were possible. Such long flights could be taxing on the pilot, so a Sperry Mark IV automatic pilot was installed.
To aid in pilot visibility, it was fitted with a rounded Plexiglas windscreen, which was put to good use shortly after the F4F-7s initial flight on December 30, 1941, when the Bureau of Aeronautics’ Lt. Cmdr. Andy Jackson flew across the country in 11 hours at an average speed of 165 mph.
When the flight plan was filed, an Army air traffic controller called the Navy and said it looked as though there was a mistake.
A Fairchild F-56 reconnaissance camera replaced the reserve tank and was placed just behind the main fuel tank. The camera was the only item that the pilot could “shoot” targets with, as there was no armament installed to save weight. Pilot armor was also not added as an additional weight-saving measure.
Such a large amount of fuel could pose a problem in a variety of situations, so two emergency fuel dump tubes were located under the rudder.
While orders for this type exceeded 100 units, only 21 were built, and these were converted to F4F-3s. Two F4F-7s were used by the 1st Marine Air Wing at Henderson Field on Guadalcanal. After being destroyed in Japanese air raids, they were replaced by aircraft from Marine Observation Squadron 251 (VMO-251).
