- IJAAF Library
- Kawasaki Ki-48
Kawasaki Ki-48
Main AdminThe Kawasaki Ki-48 (Japanese: 九九式雙發輕爆擊機, romanized: kyuukyuu-shiki-souhatu-keibaku-gekki, shortened to 'Soukei', Army Type 99 Twin-engined Light Bomber), is a Japanese twin-engine light bomber that was used during World War II. Its Allied reporting name was "Lily".
The development of the aircraft began at the end of 1937 at the request of the Japanese military high command. Kawasaki received an order to develop a "high-speed bomber" capable of 480 km/h (300 mph) at 3,000 m (9,800 ft), and able to reach 5,000 m (16,000 ft) within 10 minutes. The design was inspired by the Soviet Tupolev SB.
Kawasaki had the advantage of the experience of designing the Ki-45 twin-engined heavy fighter. Most technical problems were solved; however the aircraft had a number of shortcomings. It carried an 800 kg (1,760 lb) bombload. This was slightly less than contemporary light bombers such as the A-20 Havoc, and the similar-appearing Martin Maryland and Baltimore. Speed was intended to be its primary defense, much like the later, unarmed, de Havilland Mosquito, so it had only three machine guns (an equivalent armament to contemporary light bombers). This made it vulnerable to enemy fighters later in the war, once they became fast enough to actually catch it. The flight characteristics of the Ki-48 also left much to be desired. Newer generations of Allied fighters caught up in speed, and eventually, the Ki-48 was too slow to outrun them, while superior modern Japanese aircraft, such as the Yokosuka P1Y and the Mitsubishi Ki-67, could only be produced in small numbers. The first versions were lightly armoured, so the Ki-48 was quite aerobatic, and could loop and turn with an experienced pilot at the controls. The aircraft was often used as a dive bomber in Burma. The aircraft was not necessarily a failure, and was considered an acceptable light bomber for the first few years of the war by many historians. Much like the Mitsubishi A6M Zero fighter, it was satisfactory for the period when it was designed and produced.
The aircraft served in China from June 1940, replacing the Kawasaki Ki-32, and were widely used in the Philippines, Malaya, Burma, New Guinea, the Solomon Islands and the Dutch East Indies, where the Ki-48 Ia and Ib models, slow and badly armed, were supplemented by the marginally improved Ki-48 IIa and IIc, which were maintained in service along with the older types until the end of the war.
All models continued in service until the Battle of Okinawa during April 1945, when many were converted into kamikaze aircraft (Ki-48-II KAI Tai-Atari) armed with an 800 kg (1,760 lb) bomb. Some aircraft were modified to act as testbeds; one carried the Kawasaki Ki-148 guided missile intended for use on the Kawasaki Ki-102 in late 1944, and one was modified to test a Ne-0 pulsejet engine in late 1944 to early 1945.
The fact that all models continued in service until 1945 reflects that many Ki-48s survived more often than not. This was due to the use of small ship formations (three to ten aircraft) escorted by large numbers of fighters (25–75), typically Nakajima Ki-43s. Although not as fast as more modern fighters, after 1942, the aircraft was still fast enough to enable it to often avoid interception unless it ran into a standing patrol of fighters. The 90th Air Regiment of the 5th Air Army (based in Hopei, north China) equipped with Ki-48s was the only Japanese air unit in China proper to engage the Soviets, although others were advanced in preparation. It flew 20 sorties against the Soviets during 14 August 1945.
The British Pacific Fleet departed from Ceylon on 16 January 1945 en route to Australia and struck Japanese-held oil wells and refineries at Palembang, Sumatra on 24–29 January 1945 in Operation Meridian.
On 29 January, seven Kawasaki Ki-48 of the Army's Shichisi Mitate Tokubetsu Kōgeki Tai counter-attacked the Allied fleet at low level as the British aircraft were returning from Palembang. The British radar picture was confused by the presence of over 100 friendly aircraft, and the first two or three Supermarine Seafire CAP interceptions did not occur until just before the Ki-48 formation entered the air defence zone. The last pair of Seafires chased the five remaining Ki-48s inside the screen and, with the support of returning Vought F4U Corsairs and Grumman F6F Hellcats which had just been scrambled, shot down all of them, amongst intense AA fire. One Seafire was slightly damaged and one Hellcat was written off due to friendly fire, but the only ship to be damaged was the carrier HMS Illustrious, hit by heavy AA shells.
Ki-48
Four prototypes with 708 kW (963 hp) Nakajima Ha25 engines and five pre-production aircraft, with modified tail surfaces.
Ki-48-Ia
Army Type 99 Twin Engine Light Bomber Model 1A; as first series model. Produced from 1940, 557 built.
Ki-48-Ib,
Similar to the Ia, with changes in defensive machine gun mountings.
Total production of Ki-48 Ia and Ib: 557 aircraft
Ki-48-II
Three prototypes built.
Ki-48-IIa
Fitted with more powerful engines, a longer fuselage, additional armour, and larger bomb load. Produced from April 1942.
Ki-48-IIb
Dive bomber version, with reinforced fuselage and dive brakes.
Ki-48-IIc
Improved defensive weapons. Produced from 1943.
Total production of Ki-48 IIa, IIb and IIc: 1,408 aircraft
Ki-48-II KAI Kamikaze (Type Tai-Atari)
Conversion with 800 kg (1,760 lb) of explosives and two or three crew for kamikaze missions
Ki-66
Nose turret removed and replaced with solid nose fitted with 2x fixed forward firing 12.7mm machine guns. 8 prototypes built of varying configurations. None selected for mass production due to minimal increase in speed. Dive brakes used on Ki-48 IIb.
Ki-81
Proposed version of the Ki-48. Not built.
Ki-174
Single-seat special attack version. Not built.
Total production of all versions: 1,997 aircraft
Specifications (Ki-48-IIa)
Crew: 4
Length: 12.75 m (41 ft 10 in)
Wingspan: 17.45 m (57 ft 3 in)
Height: 3.8 m (12 ft 6 in)
Wing area: 40 m2 (430 sq ft)
Empty weight: 4,550 kg (10,031 lb)
Gross weight: 6,500 kg (14,330 lb)
Max takeoff weight: 6,750 kg (14,881 lb)
Powerplant: 2 × Nakajima Ha115 14-cylinder air-cooled radial piston engines, 843 kW (1,130 hp) each
Maximum speed: 505 km/h (314 mph, 273 kn) at 5,600 m (18,400 ft)
Range: 2,400 km (1,500 mi, 1,300 nmi)
Service ceiling: 10,100 m (33,100 ft)
Guns: 3 × 7.7 mm (0.303 in) Type 89 machine guns, in nose, dorsal and ventral positions
Bombs: 800 kg (1,764 lb) of bombs
