  • The North American Rockwell OV-10 Bronco is an American twin-turboprop light attack and observation aircraft. It was developed in the 1960s as a special aircraft for counter-insurgency (COIN) combat, and one of its primary missions was as a forward air control (FAC) aircraft. It can carry up to 3,200 lb (1,450 kg) of external munitions and internal loads such as paratroopers or stretchers, and can loiter for three or more hours.
    Background
    The aircraft was initially conceived in the early 1960s through an informal collaboration between W.H. Beckett and Colonel K.P. Rice, U.S. Marine Corps, who met at Naval Air Weapons Station China Lake, California, and who also happened to live near each other. The original concept was for a rugged, simple, close-air-support aircraft integrated with forward ground operations. At the time, the U.S. Army was still experimenting with armed helicopters, and the U.S. Air Force was not interested in close air support.
    The concept aircraft was to operate from expedient forward air bases using roads as runways. Speed was to be from very slow to medium subsonic, with much longer loiter times than a pure jet. Efficient turboprop engines would give better performance than piston engines. Weapons were to be mounted on the centerline to get efficient unranged aiming. The inventors favored strafing weapons such as self-loading recoilless rifles, which could deliver aimed explosive shells with less recoil than cannons, and a lower per-round weight than rockets. The airframe was to be designed to avoid the back blast.
    Beckett and Rice developed a basic platform meeting these requirements, then attempted to build a fiberglass prototype in a garage. The effort produced enthusiastic supporters and an informal pamphlet describing the concept. W.H. Beckett, who had retired from the Marine Corps, went to work at North American Aviation to sell the aircraft.
    Rice states:
    The military definition of STOL (500 ft to a 50-ft obstacle) allows takeoff and landing in most of the areas in which limited war might be fought. In addition, the airplane was designed to use roads so that operation would even be possible in jungle areas, where clearings are few and far between. As a result, the wingspan was to be limited to 20 feet and a heavy trailing arm-type landing gear with a tread of 6.5 ft was provided for operation from roads. Float operation was to be feasible ... ...it is quite feasible to design the various components so that it can be disassembled easily and stored in a box that would fit in a 6×6 truck bed together with the equipment needed for re-assembly in the field. It could thus be transported by amphibious shipping and either heli-lifted or driven ashore by a 6×6 truck.
    Light Armed Reconnaissance Aircraft
    A "tri-service" specification for the Light Armed Reconnaissance Aircraft (LARA) was approved by the U.S. Navy, Air Force, and Army, and was issued in late 1963. The LARA requirement was based on a perceived need for a new type of "jungle fighting", versatile, light attack and observation aircraft. Existing military aircraft in the observation role, such as the Cessna O-1 Bird Dog and Cessna O-2 Skymaster, were perceived as obsolescent, with too slow a speed and too small a load capacity for this flexible role.
    The specification called for a twin-engined, two-man aircraft that could carry at least 2,400 pounds (1,100 kg) of cargo or six paratroopers or stretchers, and be stressed for +8 and −3 g (basic aerobatic ability). It also had to be able to operate from an aircraft carrier, fly at least 350 miles per hour (560 km/h), take off in 800 feet (240 m), and convert to an amphibious version. Various armaments had to be carried, including four 7.62 mm (0.300 in) machine guns with 2,000 rounds, and external weapons including a gun pod with 20 mm (0.79 in) M197 electric cannon, and AIM-9 Sidewinder air-to-air missiles.
    Eleven proposals were submitted, including the Grumman Model 134R tandem-seat version of the already-fielded U.S. Army's OV-1 Mohawk (the U.S. Marine Corps dropped out of the Mohawk program in 1958), Goodyear GA 39, Beechcraft PD-183, Douglas D-855, Convair Model 48 Charger, Helio 1320, Lockheed CL-760, a Martin design, and the North American Aviation/Rockwell NA-300.
    In August 1964, the NA-300 was selected. A contract for seven prototype aircraft was issued in October 1964. Convair protested the decision and built a small-wing prototype of the Model 48 Charger anyway, which first flew on 29 November 1964. This was also a twin-boom aircraft that had a broadly similar layout to the OV-10. The Charger, while capable of outperforming the OV-10 in some respects, crashed on 19 October 1965 after 196 test flights. Convair subsequently dropped out of contention.
    The Bronco started flying midway through the Charger's test program on 16 July 1965, and became one of the premier COIN aircraft of the next 30 years. It did not achieve Rice's L2 VMA concept, because the DoD insisted on 40-ft-long wings, which made it depend on airbases. Rice concludes:
    Below prototypes one,two and three.
    7ab7da1f2199
    B2ab8f923d7d
    F37c223813c3
    The original concept of a small, simple aircraft that could operate close to the supported troops had been almost completely eviscerated by the 'system'. The ability to operate from roads (20 ft span and 6.5 tread) had been ignored, and performance compromised by the short 30 ft span, the extra 1,000 lb for the rough field landing gear and another 1,000 lb of electronics. The 'light, simple' airplane also had a full complement of instruments, ejection seats, and seven external store stations. The concept of using ground ordnance and a bomb bay had been ignored, although it did have provisions for four M60 machine guns. In spite of this growth (almost double the size and weight of our home built), the YOV-10 still had great potential. It would not achieve the advantages of integration with the ground scheme of maneuver, but it did have capabilities at the low end of the performance envelope that were still valuable and unique.
    The Bronco performed observation, forward air control, helicopter escort, armed reconnaissance, utility light air transport, and limited ground attack. The Bronco has also performed aerial radiological reconnaissance, tactical air observation, artillery and naval gunfire spotting, airborne control of tactical air support operations, and front-line, low-level aerial photography. A prototype in Vietnam designed to lay smoke was extremely successful, kept in service by evaluators for several months, and only reluctantly released, but was not purchased due to a perceived lack of mission.
    The OV-10 has a central nacelle containing pilots and cargo, and twin booms containing twin turboprop engines. The visually distinctive feature of the aircraft is the combination of the twin booms, with the horizontal stabilizer that connects them.
    The aircraft's design supported effective operations from forward bases. The OV-10 can perform short takeoffs and landings, including on aircraft carriers and large-deck amphibious assault ships without using catapults or arresting wires. Further, the OV-10 was designed to take off and land on unimproved sites. Repairs could be made with ordinary tools. No ground equipment was required to start the engines. If necessary, the engines could operate on high-octane automobile fuel with only a slight loss of power.
    The aircraft had responsive handling and could fly for 5 1/2 hours with external fuel tanks. The cockpit had extremely good visibility for a tandem pilot and co-pilot, provided by a wrap-around "greenhouse" that was wider than the fuselage. North American Rockwell custom ejection seats were standard, with many successful ejections during service. With the second seat removed, it can carry 3,200 pounds (1,500 kg) of cargo, five paratroopers, or two litter patients and an attendant. Empty weight was 6,969 pounds (3,161 kg). Normal operating fueled weight with two crew was 9,908 pounds (4,494 kg). Maximum takeoff weight was 14,446 pounds (6,553 kg).
    The bottom of the fuselage bore sponsons or "stub wings" that improved flight performance by decreasing aerodynamic drag underneath the fuselage. The sponsons were mounted horizontally on the prototype. Testing caused them to be redesigned for production aircraft; the downward angle of the sponsons on production models ensured that stores carried on the sponsons jettisoned cleanly. Normally, four 7.62 mm (.308 in) M60C machine guns were carried on the sponsons with the M60Cs accessed through a large forward-opening hatch on the top of each sponson. The sponsons also had four racks to carry bombs, pods, or fuel. The wings outboard of the engines contain two additional racks, one per side.
    Racked armament in the Vietnam War was usually seven-shot 2.75 in (70 mm) rocket pods with white phosphorus marker rounds or high-explosive rockets, or 5 in (127 mm) four-shot Zuni rocket pods. Bombs, ADSIDS air-delivered/para-dropped unattended seismic sensors, Mk-6 battlefield illumination flares, and other stores were also carried.
    Operational experience showed some weaknesses in the OV-10's design. It was significantly underpowered, which contributed to crashes in Vietnam in sloping terrain because the pilots could not climb fast enough. While specifications state that the aircraft could reach 26,000 feet (7,900 m), in Vietnam the aircraft could reach only 18,000 feet (5,500 m). Also, no OV-10 pilot survived ditching the aircraft.
    The OV-10 served in the U.S. Air Force, U.S. Marine Corps, and U.S. Navy, as well as in the service of a number of other countries. In total, 81 OV-10 Broncos were ultimately lost to all causes during the course of the Vietnam War, with the Air Force losing 64, the Navy 7, and the Marines 10.
    U.S. Marine Corps
    The OV-10 was first acquired by the U.S. Marine Corps. Each of the Marine Corps's two observation squadrons (designated VMO) had 18 aircraft – nine OV-10As and nine OV-10Ds night observation aircraft. A Marine Air Reserve observation squadron was also established. The OV-10 operated as a forward air controller (FAC) and was finally phased out of the Marine Corps in 1995 following its employment during Operation Desert Storm, which also saw the final combat losses of OV-10s by U.S. forces. Among these losses were two USMC OV-10s being shot down due to a lack of effective infrared countermeasures. Its slow speed was thought to make it more vulnerable to antiaircraft weapons. Forward air control passed mostly to ground units with laser designators and digital radios and the twin-seat F/A-18D Hornet (FAC(A)s). Most operational Broncos were reassigned to civilian government agencies in the U.S., while some were sold to other countries.
    The U.S. Marine Corps YOV-10D night observation gunship system (NOGS) program modified two OV-10As (BuNo 155395 and BuNo 155396) to include a turreted forward-looking infrared (FLIR) sensor, laser target designator and turreted 20 mm (.79 in) XM197 gun slaved to the FLIR aimpoint. NOGS succeeded in Vietnam, but funds to convert more aircraft were not approved. NOGS evolved into the NOS OV-10D, which included a laser designator, but no gun.
    U.S. Air Force
    The USAF acquired the Bronco primarily as an FAC aircraft. The first combat USAF OV-10As arrived in Vietnam on 31 July 1968 as part of "Operation Combat Bronco", an operational testing and evaluation of the aircraft. These test aircraft were attached to the 19th Tactical Air Support Squadron, 504th Tactical Air Support Group at Bien Hoa Air Base in South Vietnam. The test roles included the full range of missions then assigned to FAC aircraft, including day- and night-strike direction, gunship direction, bomb damage assessment, visual reconnaissance, aerial artillery direction, and as escorts for aircraft engaged in Operation Ranch Hand. The aircraft's ability to generate smoke internally was used for strike direction and "in four specific instances under conditions of reduced visibility, the smoke was seen by strike aircrews before the OV-10A was detected."Operation Combat Bronco ended on 30 October 1968.
    After the end of Combat Bronco, the USAF began to deploy larger numbers to the 19th TASS (Bien Hoa), 20th TASS (Da Nang Air Base), and for out-of-country missions to the 23d TASS (Nakhom Phanom in Thailand). The 23d TASS conducted Operation Igloo White, Operation Prairie Fire/Daniel Boone, and other special operations missions.
    Between 1968 and 1971, 26 pilots from the Royal Australian Air Force (RAAF) and Royal New Zealand Air Force (RNZAF) flew the OV-10A on FAC sorties, while attached to USAF squadrons. The 19th TASS hosted 13 RAAF pilots and three from the RNZAF; another seven RAAF pilots and three from the RNZAF were assigned to the 20th TASS. (Consequently, the Australian War Memorial has acquired an OV-10A 67-14639, which was flown by some of these pilots.)
    From April to June 1969, the USAF conducted an operational exercise called "Misty Bronco" in South Vietnam's III Corps tactical zone to evaluate the OV-10A's performance as a light strike aircraft. The results were positive, and as of October 1969, all USAF OV-10As were to be armed with their internal .308 in (7.62 mm) M60C machine guns, which had generally been left out during the Combat Bronco evaluations and subsequent deployment. High-explosive 2.75 in (70 mm) rockets were also authorized for use against ground targets.
    In 1971, the 23d TASS's OV-10A Broncos received modifications under project Pave Nail. Carried out by LTV Electrosystems during 1970, these modifications primarily included the addition of the Pave Spot target laser designator pod, and a specialized night periscope (replacing the initial starlight scopes that had been used for night operations) and LORAN equipment. The call sign Nail was the radio handle of this squadron. These aircraft supported interdiction of troops and supplies on the Ho Chi Minh Trail by illuminating targets for laser-guided bombs dropped by McDonnell F-4 Phantom IIs. After 1974, these aircraft were converted back to an unmodified OV-10A standard.
    At least 157 OV-10As were delivered to the USAF before production ended in April 1969. The USAF lost 64 OV-10 Broncos during the war, to all causes. In the late 1980s, the USAF started to replace their OV-10s with OA-37B and OA-10A aircraft. Unlike the Marine Corps, the USAF did not deploy the Bronco to the Middle East in response to the Iraqi invasion of Kuwait, as it believed that the OV-10 was too vulnerable. The final two USAF squadrons equipped with the Bronco, the 19th and 21st Tactical Air Support Squadron (TASS) retired the OV-10 on 1 September 1991.
    In 2012, $20 million were allocated to activate an experimental unit of two OV-10s, acquired from NASA and the State Department. Starting in May 2015, these aircraft were deployed to support Operation Inherent Resolve flying combat missions over Iraq and Syria, flying more than 120 combat sorties over 82 days. They reportedly provided close air support for Special Forces missions. The experiment ended satisfactorily, but an Air Force spokesman stated they are unlikely to invest in reactivating the OV-10 on a regular basis because of the overhead cost of operating an additional aircraft type.
    U.S. Navy
    The U.S. Navy formed Light Attack Squadron Four (VAL-4), the "Black Ponies", on 3 January 1969, and operated in Vietnam from April 1969 to April 1972. The Navy used the Bronco OV-10A as a light ground-attack aircraft, for interdiction of enemy logistics, and fire support of Marines, SEALs, and naval riverine force vessels.It succeeded in this role, although the U.S. Navy did lose seven OV-10s during the war to various causes.Other than OV-10 fleet replacement training done in cooperation with Air Antisubmarine Squadron 41 (VS-41) at NAS North Island, California, VAL-4 was the only squadron in the U.S. Navy to ever employ the OV-10, and it was decommissioned shortly following the end of the Vietnam War. VAL-4's surviving OV-10s were subsequently transferred to the Marine Corps.
    At least two Broncos were used as test beds in the 1970s at the Naval Air Test Center at NAS Patuxent River, Maryland.
    Two OV-10s were evaluated for special operations, and the USMC lent 18 aircraft for operation by VAL-4 in Vietnam.
    In 2015, two OV-10Gs were assigned for light attack operations in Iraq under the "Combat Dragon II" program and completed 120 missions.
    In 2019, the first of two former VAL-4 aircraft returned to flight by the OV-10 Squadron, Chino, California. Bureau numbers 155493 Holy Terror and 155474 White Lightning. Extensive restoration work of more than 18 months performed by California Aerofab went into 493's and 474's return to flight.
    Colombia
    In 1991, the USAF provided the Colombian Air Force with 12 OV-10As. Later, three ex-USMC A-models were also acquired to provide parts support. Colombia operates the aircraft in a COIN role against an active insurgency. At least one aircraft has been lost in combat.The remaining OV-10As were upgraded to OV-10D standard. In November 2015, and after 24 years of service, the Colombian Air Force retired all of its remaining OV-10 aircraft.
    Germany
    The OV-10B variant was produced for Germany to use as target tug. Eighteen aircraft were delivered in the late 1960s and they were equipped with target towing equipment inside the fuselage. A transparent plastic dome replaced the rear cargo door and a rear seat was installed in the cargo bay to look backwards out of the dome. After a long career the Bronco was replaced by the Pilatus PC-9 in 1990 and all aircraft were retired and sent to various museums, technical schools, and used in aircraft battle damage repair.
    Indonesia
    The Indonesian Air Force purchased 16 OV-10F aircraft in 1976.The aircraft were ferried across the Pacific Ocean from Wright-Patterson AFB to the Halim Perdanakusuma Airport via Alaska, Aleutians, Midway, Wake Island, Guam, and Clark Field.They were operated in COIN operations similar to the U.S. Navy's Vietnam missions with their Broncos, but retrofitted .50 cal (12.7 mm) Browning heavy machine guns in place of the .30 cal (7.62 mm) machine guns. These aircraft were based in Abdulrachman Saleh Air Force Base in Malang, East Java.
    In October 1976, three OV-10F were deployed to the Penfui Airport in West Timor, starting its vital career in the invasion of East Timor and ensuing COIN operations. During the operations in East Timor, the OV-10F flight were given the callsign "Kampret" (microbat). Starting in February 1977, up to six OV-10F were based at Dili Airport, with Baucau Airport serving as frontline airbase. During its initial years, the Indonesian Air Force modified the aircraft bomb racks to carry Soviet-made bombs and rockets as a stopgap measure, as U.S.-supplied bombs would only be received in early 1980. During its 23 years of operation in East Timor, two OV-10F were lost in non-combat accidents, with two went missing and one killed.
    In 1977, the OV-10Fs were used during the aerial bombardments of Amungme villages near Freeport-McMoRan area of operations, West Papua, in response to OPM attacks on the mining company facilities, and of Dani villages in Baliem Valley, also in West Papua, in response to rebellion against enforced participation in the Indonesian general election.
    At the start of the 2003–2004 Indonesian offensive in Aceh on 19–20 May 2003, the OV-10Fs were providing air support for airborne landings in Banda Aceh and Takengon.
    The Indonesian Air Force grounded their OV-10Fs following a fatal accident on 23 July 2007.[44] They were replaced by Embraer Super Tucanos in 2012.
    Morocco
    The Royal Moroccan Air Force acquired six former U.S. Marine Corps OV-10As in 1981, which were flown to Morocco from Columbus, Ohio, via Canada, Greenland, and Iceland. They were accompanied by fifteen US Marines from VMO-1 and VMO-2, who formed a mobile training team. The aircraft were based in Marrakesh Menara Airport, where they were employed in COIN operations against Polisario forces in the Western Sahara War using rocket pods and gun pods. One was shot down in 1985, with the loss of its pilot.
    Philippines
    The Philippine Air Force (PAF) received 24 OV-10As from U.S. stocks in 1991, later followed by a further nine from the United States, and eight ex-Thai Air Force OV-10Cs in 2003–2004. The OV-10s are operated by the 16th Attack Squadron and 25th Composite Attack Squadron of the 15th Strike Wing, based in Sangley Point, Cavite. The PAF flies Broncos on search-and-rescue and COIN operations in various parts of the Philippines. The first two women combat pilots in the PAF flew OV-10s with the 16th. This squadron flew anti-terrorist operations in the Jolo island.
    PAF OV-10 Broncos were repeatedly used in air strikes against Moro Islamic Liberation Front positions during ongoing fighting in 2011, and two were used in an air strike in February 2012, which resulted in the death of three Abu Sayyaf and Jemaah Islamiyah commanders, among others. Philippine Air Force OV-10s have been reportedly modified in order to employ modern smart bombs.
    On 1 June 2017, the PAF OV-10s dropped bombs on Maute group positions during the Battle of Marawi.
    The PAF announced that its remaining OV-10s will be replaced by the Embraer EMB 314 Super Tucano by 2024. This is to meet requirements set by the AFP Modernization Act to replace the aging aircraft.[57] The OV-10s had finally withdrawn from service on 28 December 2024.
    Thailand
    The Royal Thai Air Force purchased 32 new OV-10C aircraft in the early 1970s for COIN usage. Reportedly, Broncos won most Thai bombing competitions until F-5Es became operational. At one time, the RTAF flew OV-10s as air-defense aircraft. In 2004, RTAF donated most of the OV-10s to the Philippines. Three OV-10 survivors are displayed, one at the Tango Squadron Wing 41 Museum in Chiang Mai, the RTAF Museum in Bangkok, and a static display at the main gate of Wing 5 in Prachuap Khiri Khan. The remaining OV-10s were to be donated to the PAF in 2011.
    Venezuela
    The Venezuelan Air Force has operated a number of new-build OV-10Es and ex-USAF OV-10As over the years. On 27 November 1992, the aircraft were widely used by mutinous officers who staged an attempted coup d'état against former President Carlos Andrés Pérez. The rebels dropped bombs and launched rockets against police and government buildings in Caracas. Four Broncos were lost during the uprising, including two shot down by a loyalist General Dynamics F-16 Fighting Falcon.
    Venezuela's OV-10s are to be retired in the coming years. Originally, Venezuela attempted to procure Embraer Super Tucano aircraft to replace the OV-10, but no deal was achieved, which President Chavez claimed was due to the result of pressure from the U.S. government. The Venezuelan government has decided not to replace them with new fixed wing aircraft. Rather, the Venezuelan Air Force is replacing them with the Russian made Mil Mi-28 attack helicopter.
    California Department of Forestry and Fire Protection
    The California Department of Forestry and Fire Protection (CALFIRE) has acquired a number of OV-10As, including the six surviving aircraft from the BLM and 13 former U.S. Marine Corps aircraft in 1993 to replace their existing Cessna O-2 Skymasters as air-attack aircraft.The CAL FIRE Broncos fly with a crew of two, a contract pilot and the CAL FIRE ATGS or Air Tactical Group Supervisor, whose job it is to coordinate all aerial assets on a fire with the Incident Commander on the ground. Thus, besides serving as a tanker lead-in aircraft, the OV-10A is also the aerial platform from which the entire air operation is coordinated.
    5a6618698f3e
    5a6826a27ccf
    C6976dbc09c9
    E46c59c912e0
    Dead8d7d8144
    225147e080e5
    D277644358f4
    C8430b4028a2
    A501b3633fbc
    9d28c8e6c241
    Cd1eff26b9e2
    A70dec483666
    Ff595a164c3c
    B2a976a7f87d
    6d04c67a7eed
    86a8da5c5ce3
    42fb9fef92b7
    D420af178e55
    Dab90d3456e1
    E0a90f0e88aa
    Specifications (OV-10D)
    Capacity: cargo compartment for personnel (no seats) or 3,200 lb (1,451 kg) of freight
    Length: 44 ft 0 in (13.41 m)
    Wingspan: 40 ft 0 in (12.19 m)
    Height: 15 ft 2 in (4.62 m)
    Wing area: 291.0 sq ft (27.03 m2)
    Airfoil: NACA 64A315[124]
    Empty weight: 6,893 lb (3,127 kg)
    Gross weight: 9,908 lb (4,494 kg)
    Max takeoff weight: 14,444 lb (6,552 kg) (overload)
    Fuel capacity: 252 US gal (210 imp gal; 950 L) internal
    Powerplant: 2 × Garrett T76-G-420/421 turboprop engines, 1,040 shp (780 kW) each equivalent
    Propellers: 3-bladed Hamilton Standard, 8 ft 6 in (2.59 m) diameter constant-speed fully feathering propellers
    Maximum speed: 250 kn (290 mph, 460 km/h) at sea level
    Combat range: 198 nmi (228 mi, 367 km)
    Ferry range: 1,200 nmi (1,400 mi, 2,200 km) with auxiliary fuel
    Service ceiling: 30,000 ft (9,100 m)
    Rate of climb: 3,020 ft/min (15.3 m/s)
    Take-off run: 740 ft (226 m)
    Take-off distance to 50 ft (15 m): 1,120 ft (341 m)
    Take-off distance to 50 ft (15 m): 2,800 ft (853 m) at MTOW
    Landing run: 740 ft (226 m)
    Landing run: 1,250 ft (381 m) at MTOW
    Landing distance from 50 ft (15 m): 1,220 ft (372 m)
    Guns: 1 × 20 mm (0.79 in) M197 electric cannon (YOV-10D) or 4 × 7.62×51 mm M60C machine guns (OV-10D/D+)
    Hardpoints: 5 fuselage and 2 underwing , with provisions to carry combinations of:
    Rockets: 7- or 19-tube launchers for 2.75 in (70 mm) FFARs/WAFARs or 2- or 4-tube launchers for 5 in (127 mm) FFARs or WAFARs
    Missiles: AIM-9 Sidewinder on wings only
    Bombs: up to 500 lb (227 kg)
