- Campains for Kursk_RRR map by Cyberolas?
Level 2Hi.
Downloaded and installed Kursk_RRR map by Cyberolas to my DBW 1.7. Made a quick and small mission i FMB to test it out. What a' lovely map and fantastic senario's. Would like to have some more campains made or possible to run on this map. All dl.links to sutable campains are very welcome.
In the end of the trailer on You-Tube for this map, is mentioned a " Stuka Leader:Kursk" campain. Any one know where to find this? or is it a WIP project?
You-Tube link:
http://www.youtube.com/watch?v=-cUYsogoxio&list=PL504B397D9356817F&index=49&feature=plpp_video
Special thanks to Cyberolas for this and the other RRR maps Kuban and Crimea.
Regards
Odin1one
Main AdminYou can easily have these textures for the Prokhorovka map also: Add a folder into the #DBW folder called
\MapMods\maps\Prokhorovka and copy the load.ini from Cyberolas Kursk map into it - that?s all, no all.ini editing or other stuff needed; with that you can enjoy my Kuban campaign with it:
http://www.axis-and-allies-paintworks.com/download.php?view.526
which has a part "Operation Zitadelle"
Level 2Thanks! Boelcke.
I will try that out. -
Level 2Yes. Boelcke.
Worked out great.
Giv you Some quick shoots from first misson "Zitadelle" and a train attack. Cold not stay with the escort flight as was the
mission task. Had to take e closer look at the map texture and there it was "Red army suply train" just running up
as for target practise.
Made 3 attack runs and than hit for home..
Look forward to play the rest and other parts of your Kuban campaign.
Know and played some of your other's, a realy pleachure to play.
Thanks again!
11 years agoWed Sep 26 2012, 01:11pmLevel 1Nice screenies, I like these textures too, thanks for the heads up guys.
Boelcke's Kuban campaign is a masterclass - nice to see the return of his 'Made in Germany' section in Mission Builders HQ. -
11 years agoLevel 3That map looks incredible! Looking forward to getting out of the desert (it's been two years now - all my own fault of course!).
Main Adminthx for the pics Odin1one, i've started to populate the subcampaign with a lot more objects, but i can't do all these campaign simultaniously ... so it has to be delayed as long as i'm working on other stuff
Very nice screens Odin.
Level 1Got these repaints in TFM now.
