- Project Yehudi
Project Yehudi
12 years agoMain AdminDaytime Running Lights
TODAY'S EXPERIMENTS with visual stealth have their roots in a 1943 U.S. Navy project code-named Yehudi. The intent of the program, which was highly secret at the time and came to light only in the1980s, was to give Navy patrol aircraft a better chance of sinking enemy submarines. During 1942, German U-boats took a heavy toll on merchant marine shipping off the East Coast of the United States. Aircraft scrambled to attack the U-boats, but submarine captains called for crash dives whenever they spotted approaching planes. By the time an aircraft got close enough to fire upon a sub, it had disappeared beneath the surface of the ocean.
Yehudi's inventors needed a way to make the antisubmarine aircraft harder to see, and they realized that camouflage paint wouldn't do the job: Regardless of its color, the airplane would stand out as a black dot against the sky. The only way to make the plane less visible was to light it up like a Christmas tree.
The engineers fitted a portly TBM-3D Avenger torpedo-bomber with 10 sealed-beam lights installed along the wing's leading edges and the rim of the engine cowling. When the intensity of the lights was adjusted to match the sky, the Avenger blended into the background. Tests proved that the Yehudi system lowered the visual acquisition range from 12 miles to two miles, allowing the Avenger to get within striking distance of its targets before they submerged. A B-24 Liberator bomber was also modified, with similar results.
Yehudi was not put into production, because better radar had already enabled Navy airplanes to regain the tactical advantage, but the idea was revived after air battles over Vietnam. Concerned that the big F-4 Phantom could be seen at a greater range than its much smaller Russian adversary, the MiG-21, the Pentagon started a program called Compass Ghost. An F-4 was modified with a blue-and-white color scheme and nine high-intensity lamps on the wings and body. reducing the detection range by as much as 30 percent.
