- Fw 190 D-9 WNr. 400616 "Weisse 16" III./JG 54 "Gr?nherz"
13 years ago
Main AdminNever new about this, being restored for static display.
Link - http://www.sandyair.com/index.php?page=aircraft -
13 years ago
AdminNice, look forward to see her restored. -
AdminDoes anyone have more information about the recovery of WNr. 400616? -
13 years ago
Main AdminA bit of a mystery this one.
More info here - http://forum.12oclockhigh.net/showthread.php?t=34412 -
13 years ago
Main AdminWOW
Main Adminvery impressive, but the made some small errors with the restauration of the paintings, it was common for III./JG 54 Doras that the Spiral was only on the tip of the spinner and a WNr 400 xxx has to have a much more dense motteling which was typical for a Fieseler build aircraft -
AdminI am not sure if 'restoration' is really the right expression in this particular case. Obviously they only just a small number of original parts. -
13 years agoMon Jul 01 2013, 02:22am
Level 1I have yet to see a good paint restoration on German fighters. The saddest piece of work was the repainting of D -13 that was owned by Champlin before sending it up to Washinton. There was a original scheme on it and it was
destroyed so that a very badly painted defensive scheme could be done to replace the original which had no major rusting. What buggers. Hey no one will ever know. -
Level 3Jurri and RDDR are right. Not so much a restoration as a one to one , life- size model. and with a poorly researched paint scheme intended to add spurious "glamour" to an aircraft which probably had a prosaic service history.
Lets hope the Dornier recently recovered from the English Channel doesn't suffer the same ignominious fate.
Wingco.
