- Edo XOSE-1
Edo XOSE-1
										12 years ago Main AdminThe Edo Aircraft Corporation was an established company that produced seaplane floats. In 1946, Edo designed its first aircraft, the Edo OSE. Two prototype aircraft (designated XOSE-1) were built and flown in 1946. The XOSE-1 was a single-seat low-wing cantilever monoplane with a single float and fixed wingtip stabilizing floats. The wings could be folded for shipboard storage. The aircraft was designed for a variety of roles including observation and anti-submarine patrols. Unusually, it was designed to carry a rescue cell on the underwing hardpoints, which would be capable of carrying a single person when used for air-sea rescue. Eight production aircraft (designated OSE-1) were built to a United States Navy order but none were accepted into service. A two-seat training conversion was carried out as the XTE-1, but production TE-2 aircraft were cancelled. Main AdminThe Edo Aircraft Corporation was an established company that produced seaplane floats. In 1946, Edo designed its first aircraft, the Edo OSE. Two prototype aircraft (designated XOSE-1) were built and flown in 1946. The XOSE-1 was a single-seat low-wing cantilever monoplane with a single float and fixed wingtip stabilizing floats. The wings could be folded for shipboard storage. The aircraft was designed for a variety of roles including observation and anti-submarine patrols. Unusually, it was designed to carry a rescue cell on the underwing hardpoints, which would be capable of carrying a single person when used for air-sea rescue. Eight production aircraft (designated OSE-1) were built to a United States Navy order but none were accepted into service. A two-seat training conversion was carried out as the XTE-1, but production TE-2 aircraft were cancelled.
 S2E-1
 Original designation for OSE and TE single seat floatplane scouts.
 OSE-1
 Prototypes and production single-seat aircraft re-designated from S2E-1; eight built.
 XOSE-2
 Prototype two-seat floatplane scout aircraft, two converted from OSE-1.
 OSE-2
 Production two-seat floatplane scout aircraft, four aircraft were assigned Bureau of Aeronautics numbers (BuNos.), but production was cancelled.
 XSO2E-1
 Original designation for XTE-1 conversions.
 XTE-1
 Two-seat floatplane trainer conversions from OSE-1, two aircraft converted from the XOSE-1 prototypes.
 TE-2
 Developed from the TE-1, four aircraft were assigned BuNos., but production was cancelled.
 Crew: One
 Length: 31 ft in (9.47 m)
 Wingspan: 37 ft 11 in (11.57 m)
 Height: 14 ft 11 in (4.55 m)
 Empty weight: 3,973 lb (1802 kg)
 Gross weight: 6,064 lb (2751 kg)
 Powerplant: 1 ? Ranger V-770-8 piston engine, 550 hp (410 kW) each
 Maximum speed: 198 mph (319 km/h)
 Range: 900 miles (1448 km)
 Service ceiling: 22,300 ft (6800 m)
 two fixed forward-firing wing-mounted 0.5in (12.7mm) machine-guns
 Underwing racks for two 350lb (159kg) depth charges
