- Bristol XLRQ-1 Amphibious Glider
12 years agoSun Oct 27 2019, 12:13pm
Main AdminInspired by the use of gliders by Germany, the United States Navy and USMC initiated a glider program in May 1941. Two glider types were envisioned, a 12-seat and a 24 seat-type. The Naval Aircraft Factory was requested to undertake preliminary design of the gliders, which were to be constructed of wood or plastic. The idea was to have enough gliders to transport one battalion of Marines (715 men) with equipment. Consolidated PBYs should be used to tow the gliders.The Marines requested a glider capable of landing and take off from both land and water, be capable of static line parachute jumping and have exterior machine guns.
In 1942 the USMC established Marine Glider Group 71 at Page Field, Parris Island, South Carolina (USA), using the Schweizer LNS-1 and Pratt-Read LNE-1, later also Aeronca LNR-1 gliders for training. For towing the unit used N3N Canary biplane trainers and J2F Duck amphibians.
For the 12-seat type the beach assault role in mind, the U.S. Navy ordered prototypes, the Allied Aviation Corporation XLRA-1 and the Bristol Aeronautical Corporation XLRQ-1. Technically, the gliders were successful designs, and 100 of each were ordered. Also a licence production by the Naval Aircraft Factory as the LRN-1 was envisioned.
Although the U.S. Navy ordered four XLRQ-1 prototypes, only two were built (BuNos 11561 and 11562). The glider had a retractable landing gear and the wing roots provided lateral stability on the water.
However, glider assault was not tactically feasible against small, heavily defended islands in the Pacific, not enough gliders were arriving from factories and too many pilots were being assigned to the glider program Therefore the program was scrapped in 1943.
Crew: two pilots
Capacity: 10 troops
Length: 40 ft 0 in (12.2 m)
Wingspan: 72 ft 0 in (22.0 m)
Height: 12 ft 3 in (3.7 m) each each
