- The Workshop
- Works in Progress
- B-25J Dark Olive Drab Skin
9 years agoSat Feb 15 2014, 01:43pmLevel 6I'm happy to announce some skins I've been working on. They're not from any B-25 Squadron or Bomb Group, but I think you guys will like'em.
Skin features:
1- Red Cowl Rings and tips of the vertical stabilizers.
2- Dark OD over Bare Metal.
3- Redesigned tail turret, for more accuracy, as those were more square-shaped with rounded edges.
4- One or two might be decorated with Tail Numbers and Mario Themed Noseart. -
Main AdminTo upload photo's you need to use "Photobucket" or some similar hosting program.
Level 6Thanks, Duggy.
9 years agoTue Dec 03 2013, 02:09amLevel 6
9 years agoMon Dec 02 2013, 06:47pmLevel 1Maty, I sent you the OD Patches to you? Right?
Your colors are incorrect .
Go back and take another look.
On the other hand I see you have progressed from
where you started. You have been using Gimp?
It's gonna take a while It does not happen over night
Don't get pissed . Your getting free advice Buddy.,
Get back to the hanger and check out the OD paint colors
This is a order Shave Tail,
Level 6Thanks for the tip. What's Shave Tail?
AdminHi Maty,
If you'd like the images to appear here in the thread, just add [ img ] infront of the "http://s.949 etc etc etc" and [ /img ] at the end after the ".html" (delete the spaces I added between the [ and their contents, I added them so the site doesn't think there're images to show)
9 years agoMon Dec 02 2013, 08:59pmLevel 6Thank you, HB, but I can't see them. Can you?
9 years agoTue Dec 03 2013, 12:42amLevel 6"You do not have the correct permissions to upload files to this server." What does this mean?
9 years agoTue Dec 03 2013, 01:54amAdminDoh! Sorry, I got my explanation a little wrong... when viewing your image in Photobucket there's a panel on the right hand side called "Links to share this photo", left click on the code next to "Direct" and it will copy that code. Paste that code between those [ img ] [/ img ].
As for being unable to upload skins, another recently asked the same question so I've copied and pasted what I said to him below:
Unfortunately you won't be able to upload your skins as only Admins can upload content (I believe the 'Upload' button at the top of the window is a leftover from the old site where public uploads were possible however that is no longer the case on this, our new server), however if you feel like some help or have questions about your skins please don't hesitate to post a thread in the w.i.p section.
Regards,
HB
