- Defense of the Reich campaign for Il2 4.12 and Asuras dgen.xe mod uploaded
just uploaded the Defense of the Reich campaign for Il2 4.12 - a dedicated version for HSFX 7 will follow
What is needed to play the campaign:
- working with IL2 V 4.12 only!!!!
- Asuras DGEN.EXE mod: It?s Version 2.0.1.0 or better
http://www.axis-and-allies-paintworks.com/download.php?view.807
Included is
- a Luftwaffe fighter campaign from 1943-45 and (Defense of the Reich)
- an USAAF fighter campaign 1943-45. (Battle over Germany)
The USAAF fighter campaign has mostly airstarts.
the campaign is available here:
http://www.axis-and-allies-paintworks.com/download.php?view.822
New features:
- the fighter ecsorts are staying now with the bomber formations
- real masses of bombers
- more than 100 planes in the air
- more than one mission a day possible
Kown issues:
- atm there is an bug in Asuras dgen.exe mod existing, that every now and then a night mission appears if more than one mission a day is counted
Attention:
This campaign is a real hardware killer, more than 100 planes in the air and the Berlin map is very hardware demanding as well - if you can?t play the campaign with your hardware, i?m sorry but there will be no version available with a reduced number of aircrafts, cause it?s finaly a real feeling of air combat with masses of planes - to reduce the umbers don?t make sense for me.
Keep in mind:
The campaign does work only with Il2 4.12 and Asuras dgen mod - never ever with stock dgen.exe! -
Level 7wow! Heavy action, lots of contrails and bombers. What are the odds of the LW pilot to survive? -
Main AdminHard
12 years ago
Level 1Thank you
I will downloaded it as soon as I am back home -
AdminAn advice for those who are having performance problems because of the large bomber formations. Using GroundIntensity=Low, MaxFLAK=5 and NoAirfieldHighlight in the DGen_mod.ini file can improve the performance. -
Level 1I downlloaded last night Detlef,
Just have see that I have everything in order -
12 years agoWed Dec 11 2013, 09:20am
Juri_JS
sorry, but that will differ the campaign completely from what was intended
i have added a lot of ground objects in some parts of the campaign and adjusted the number off AA guns to the value MaxFLAK=40 so that there is enough but not to much flack fire explosions around the bombers, for max immersion - if you have performance problems, it?s much better tp play the former version of the campaign, made for stock Il2 4.11 or better, which will work with stock dgen.exe and Asuras dgen.exe mod as well
