  • Team Daidalos has released update 4.13.1:
    http://forum.1cpublishing.eu/showthread.php?t=229683
    New flyable planes (include new added cockpits):
    - R-5, 1931? (with 1934 model cockpit);
    - P-5, 1931? (trainer based on R-5);
    - S.S.S ("Three S"), 1936?;
    - He-111H-11, 1942?;
    - He-111H-16, 1943?;
    - I-16 type 28, 1939?;
    - I-16 type 29, 1940?;
    - I-153 M63, 1940? (with M-63 engine);
    Improved cockpits:
    - I-15bis;
    - I-16 type 24;
    - I-16 type 24SPB;
    - I-153 M62;
    - I-153P;
    - Pe-2 (added complete radio operator cockpit).
    - He-111H-2, He-111H-6, He-111H-12 (cockpit interior update).
    - He-111H-6 (added one more gunner post at ventral gondola).
    New ground units:
    - Total rework of all railway cars 3D-models.
    - Armored train BP-42 (Germany).
    - Armored train BP-44 (Germany).
    - Armored train OB-3 (USSR).
    - Armored train NKPS-42 (USSR).
    - Tank T-26 model 1931?. (Twin turrets).
    - Update camo for T-26(late) tank.
    - Tank BT-5.
    - Tank BT-5RT (BT-5 command tank with radio).
    - Update tank BT-7 3D-model.
    - Tank BT-7A (with short-barreled 76mm cannon).
    - Tank BT-7RT (BT-7 command tank with radio).
    - Rework tank KV-1 3D-model.
    - Tank KV-1S.
    - Tank KV-2.
    - Tank Vickers Mk.? Mod.F (Finnish).
    - Tank destroyer SU-152.
    - Armored car BA-20.
    - Update armored car BA-10 3D-model.
    - Rework armored car BA-64 3D-model.
    - Mortar BM-82, model 1937 (1942 production).
    - Rework Sd.Kfz.184 "Ferdinand" 3D-model.
    - Update camo for T-34 tank.
    New ships:
    - Torpedo boat D-3 (USSR).
    New maps:
    - Black Sea (combined map, includes Crimea and Kuban territory).
    New features:
    - Locomotives valve gear and other chassis animation.
    - Turning on lights on locomotives at night.
    - Updated Norden and Lotfe-7C bombsights, reduced TAS switching step.
    - Added key for switching ballistic tables then using bombsights.
    - New regiments and insignias (over 900).
    - New soviet bombs AO-8M3, RRAB-520.
    - Added "conf.ini" option Mouse6DOFMove=1 under [game]. This will enable automatic offset to sideboards then player looks back using mouse.
    - Fighting ground vehicles and combat ships can use salvo firing with all available barrels.
    Changes & Improvements:
    - Fixed wheel brakes working, with keyboard operation - balance between left and right wheel brakes considered with rudder position.
    - Fixed damage model and made some minor cockpit changes for SM.79.
    - Fixed errors that displayed incorrect operation altitude for parachute armaments and SABs in Dedicated Server mod.
    - Full rework of bomb loadout variants for R-5 (for historic ones only). Old missions may be incompatible with new loads.
    - Increase of bomb loadout variants of He-111H-6 (for historic ones only). Old missions are still compatible.
    - Sliding canopy of dorsal gunner in He-111H-2/He-111H-6 variants, thus increasing their firing angles.
    - Fixed (blocked) opportunity to remove marker symbol in the "Misc.settings", under "Markers", which may cause the game to fail to run.
    - New default camo for all LaGG-3 planes.
    - New camo for P-39N-1 Pokryshkin plane.
    - Fixed network bug, with incorrect turret position transmitted to other players.
    - Fixed network (and NTRK) bug, with incorrect player position in cockpits (for co-pilots crew planes).
    - Fixed error "ID_10" occurred sometimes while Dedicater Server mission was loading.
    - Fixed error in output of drift angle, on the B5N bombsight.
    - Updated 3D-model of AO-10 bomb.
    - Added new loadouts for I-153 M-62 plane, includes BS machinegun (based on historical photos).
    - Some fixes on Solomons map.
    - All missing bridges added on Slovakia autumn map.
    - Added new damage model for "Periscope" objects ? now it is possible to hit submerged submarines along the full length of the hull.
    - Some fixes for "DShK machinegun" objects.
    - Fixed self-propelled heavy mortar "Karl". From now on it has really high-angle barrel elevation with correct firing distance and realistic shell types.
    - Some fixes in COOP (but multicrew mod is still experimental and a little bit buggy).
    - Fixed user console and server log spamming errors from parachute armaments and SABs.
    - Fixed prop rotation direction of the N1K1J, N1K1Ja, N1K1Jb.
    - Fixed prop rotation direction of the P-40E(M-105PF).
    - Fixed cannons ATG38_45mm, ATG42_45mm, RG43_76mm.
    - Fixed 3D-model of armored car FAI-M.
    - Activated AAA position on the turret of battleship "Tirpitz".
    - Activated AAA positions on the turrets of battleships "King George V" class.
    - Activated inner turrets of battleship "Marat", and they can fire in both port and starboard directions.
    - All appropriate ships can fire from torpedo-tubes on both sides (mostly for destroyers).
    - Changed 3D-model and technical data for destroyer torpedoes from default noname to 533-mm model 53-38.
    - Added correct sounds for armored rail-cruiser MBV ?002.
    - Fixed (corrected) sounds of moving rolling stock.
    - Stationary railway cars have winter PaintSchemes.
    - Some trains have new antiaircraft platform position ? it is transferred to the head or tail of a rolling stock.
    - Added new locomotive steam effects: additional steam emissions in the beginning of movement and before the stop.
    - Fixed number of single bomb releases for the Ju-88 to a total of 24. Also fixed some errors with bombsight automation (denial of bomb release for some loadout types).
    - Fixed armament of the T-28 and T-35 tanks.
    - Added/changed Customization.ini files for S.S.S., I-15bis, I-153, and new types I-16.
    - Fixed default desert camo for B-24. Increased camo list.
    - Corrected bombing equipment hard points on the P-40.
    - Corrected shape of radio operator entrance hatch for the external 3D-model of Pe-2 ser.359.
    - Changed cockpit lights inside the SB-2 M-100A and SB-2 M-103.
    - Changed damage level for controls for all Il-2 planes.
    - Added damage model for "American tractor" stationary object.
    - Added stationary plane YaK-7B(M-105PF).
    - Fixed speed indicator accuracy for P-38. Speed indicator output now shown in mph as indicated on cockpit gauge instead of KIAS (Knots-Indicated Air Speed).
    - And some more minor fixes and corrections
  • Alright! Looking forward to checking it out smile
