- IJAAF Library
- Mitsubishi Ki-57
Mitsubishi Ki-57
4 months ago
Main AdminThe Mitsubishi Ki-57 was a Japanese passenger transport aircraft, developed from the Ki-21 bomber, during the early 1940s.
In 1938, when the Ki-21 heavy bomber began to enter service with the Imperial Japanese Army, its capability attracted the attention of the Imperial Japanese Airways. In consequence, a civil version was developed, and this, generally similar to the Ki-21-I and retaining its powerplant of two 708 kW (950 hp) Nakajima Ha-5 KAI radial engines, differed primarily by having the same wings transferred from a mid- to low-wing configuration and the incorporation of a new fuselage to provide accommodation for up to eleven passengers. This transport version appealed also to the navy, and, following the flight of a prototype in August 1940 and subsequent testing, the type was ordered into production for both civil and military use.
This initial production Ki-57-I had the civil and military designations of MC-20-I and Army Type 100 Transport Model 1, respectively. A total of one-hundred production Ki-57-Is had been built by early 1942, and small numbers of them were transferred for use by the Japanese Navy in a transport role, then becoming redesignated L4M1. After the last of the Ki-57s had been delivered, production was switched to an improved Ki-57-II, which introduced more powerful 805 kW (1,080 hp) Mitsubishi Ha-102 14-cylinder radial engines installed in redesigned nacelles and, at the same time, incorporated a number of detail refinements and minor equipment changes. Civil and military designations of this version were the MC-20-II and Army Type 100 Transport Model 2, respectively. Only 406 were built before production ended in January 1945. Both versions were covered by the Allied reporting name Topsy.
Below civil
Below military
Specifications (Ki-57-II)
Crew: 4 (pilot, co-pilot, navigator and radio operator)
Capacity: 11 passengers
Length: 16.1 m (52 ft 10 in)
Wingspan: 22.6 m (74 ft 2 in)
Height: 4.86 m (15 ft 11 in)
Wing area: 70.08 m2 (754.3 sq ft)
Empty weight: 5,585 kg (12,313 lb)
Gross weight: 8,173 kg (18,018 lb)
Max takeoff weight: 9,120 kg (20,106 lb)
Powerplant: 2 × Mitsubishi Ha-102 Zuisei 14-cylinder air-cooled radial engine, 805 kW (1,080 hp) each for take-off
Maximum speed: 470 km/h (290 mph, 250 kn) at 5,800 m (19,000 ft)
Range: 3,000 km (1,900 mi, 1,600 nmi)
Service ceiling: 8,000 m (26,000 ft)
Time to altitude: 5,000 m (16,000 ft) 15 minutes 45 seconds
Wing loading: 116.6 kg/m2 (23.9 lb/sq ft)
